AndyCanning Posted September 16, 2005 Share Posted September 16, 2005 my airbag light flashes 4 times stops for a sec then does it again, its gettin annoyin now. any help? i even unplug the wires under the seat and it still does the same. Link to comment Share on other sites More sharing options...
Muzz Posted September 16, 2005 Share Posted September 16, 2005 Just remove the bulb inside the clocks . Link to comment Share on other sites More sharing options...
RobMk6 Posted September 16, 2005 Share Posted September 16, 2005 dodgy connection under the seats probably, course it will do it if you unplug them just check and make sure all the connections are in good nick Link to comment Share on other sites More sharing options...
AndyCanning Posted September 16, 2005 Author Share Posted September 16, 2005 dodgy connection under the seats probably, course it will do it if you unplug them just check and make sure all the connections are in good nick i ment i have unattached it and reattched it and it still does the same, Link to comment Share on other sites More sharing options...
RobMk6 Posted September 16, 2005 Share Posted September 16, 2005 oh right okay, all i can suggest is to check all the connections properly, other than that i have no idea as mine was always dodgy connections Link to comment Share on other sites More sharing options...
BlairM Posted September 16, 2005 Share Posted September 16, 2005 Have you done the connection on the passenger seat too. Remember this nearly got me taking the bulb out once too, until I unplugged the passengers side Link to comment Share on other sites More sharing options...
Mk6 Si Ross Posted September 17, 2005 Share Posted September 17, 2005 i've checked both plugs n they're ok, my light stays on all the time!!! anyone know what that means??? Link to comment Share on other sites More sharing options...
Muzz Posted September 17, 2005 Share Posted September 17, 2005 i've checked both plugs n they're ok, my light stays on all the time!!! anyone know what that means??? A fault with the airbag itself. Either a loose wire internally or the airbag needs replacing. Link to comment Share on other sites More sharing options...
Mk6 Si Ross Posted September 17, 2005 Share Posted September 17, 2005 i've checked both plugs n they're ok, my light stays on all the time!!! anyone know what that means??? A fault with the airbag itself. Either a loose wire internally or the airbag needs replacing. so not belt/seat related then anyway!?? bulb out then Link to comment Share on other sites More sharing options...
