2.0Si Posted September 16, 2006 Share Posted September 16, 2006 Ive just came in, what happened was every now and again i gave the car some stick and used harsh braking, the brake pedal would go solid and impossible to press, this means the brakes fail Done this a few times now but not so severe, about 4 weeks ago the brake pads started grinding, i bought a new set, only to discover the drivers side pads where only 3/4 worn, the passenger side one was 3/4 worn, then the inner pad was a piece of thin, heat damaged metal about 4mm thick, proper bollocksed and the disc is dead too... Is this suspect dodgy pass side caliper? is it sticking? why does the brake pedal go rock solid when i brake harshly and then the brakes fail almost completely? Link to comment Share on other sites More sharing options...
madxrcabby Posted September 16, 2006 Share Posted September 16, 2006 i would ring up ford Link to comment Share on other sites More sharing options...
Carl160180 Posted September 16, 2006 Share Posted September 16, 2006 Sound's like you got a sticky caliper mate ! Link to comment Share on other sites More sharing options...
SaMMy125 Posted September 16, 2006 Share Posted September 16, 2006 Sound's like you got a sticky caliper mate ! yeap or blocked flexi hose comon escort problem, dont think it's ur master cylinder but iv got one for sale if u need Link to comment Share on other sites More sharing options...
Trig Posted September 16, 2006 Share Posted September 16, 2006 ive got some good calipers and discs if you like, hardly any wear on them at all Link to comment Share on other sites More sharing options...
2.0Si Posted September 16, 2006 Author Share Posted September 16, 2006 I can get a caliper from the local scrappy for a tenner, but i aint going to bother fitting them, last time i tried to undo the flexi hose it just snapped off inside the caliper, then i had to buy another flexi hose, then when i tried to fit that it snapped off the other end onto the brake pipe Ill probably have to get it fitted properly and get the brakes bled too, that was bloody scary though Link to comment Share on other sites More sharing options...
SaMMy125 Posted September 16, 2006 Share Posted September 16, 2006 I can get a caliper from the local scrappy for a tenner, but i aint going to bother fitting them, last time i tried to undo the flexi hose it just snapped off inside the caliper, then i had to buy another flexi hose, then when i tried to fit that it snapped off the other end onto the brake pipe Ill probably have to get it fitted properly and get the brakes bled too, that was bloody scary though yea mate u have 2 blow torche the hoses fittins 2 get em off Link to comment Share on other sites More sharing options...
RyanML Posted September 16, 2006 Share Posted September 16, 2006 dude do you own my car or somthing lol, same thing happens to me, i just put it down to brake fade as i do eventually stop lol Link to comment Share on other sites More sharing options...
SaMMy125 Posted September 16, 2006 Share Posted September 16, 2006 dude do you own my car or somthing lol, same thing happens to me, i just put it down to brake fade as i do eventually stop lol loads of mk6's r gettin these fooked flexi pipes, spent loads before i got the goodridge hoses on, and rs front stopers, only when my flexi hose went, it locked my front left caliper nearly went down a ditch lol Link to comment Share on other sites More sharing options...
Andy_GTi Posted September 16, 2006 Share Posted September 16, 2006 ok i'm not not looking forwward to taking off my calipers ! all of thjis to take the hose off the caliper ?? yea mate u have 2 blow torche the hoses fittins 2 get em off Link to comment Share on other sites More sharing options...
Devboy Posted September 16, 2006 Share Posted September 16, 2006 i have never had to blow torch the flexi hose ends! mine have come off on my car easy and my brothers car easy heh. Link to comment Share on other sites More sharing options...
SaMMy125 Posted September 16, 2006 Share Posted September 16, 2006 i have never had to blow torch the flexi hose ends! mine have come off on my car easy and my brothers car easy heh. na not the caliper end thats well easy just a 15mm socket, it's a bonjo bolt, i had 2 blow torch the end of the flexi hose 2 copper pipe they where a shite i tell ya Link to comment Share on other sites More sharing options...
2.0Si Posted September 16, 2006 Author Share Posted September 16, 2006 Shall i try a new flexi hose first then? I cant see how it could go wrong or block? its a hose fluid either goes through it or leaks out? Link to comment Share on other sites More sharing options...
SaMMy125 Posted September 17, 2006 Share Posted September 17, 2006 Shall i try a new flexi hose first then? I cant see how it could go wrong or block? its a hose fluid either goes through it or leaks out? yea the hoses, kerode inside and stop the brake fluid movin freely thats all Link to comment Share on other sites More sharing options...
