Joe Posted September 23, 2006 Share Posted September 23, 2006 hiim trying to take off the rear door cards but can not get the window winders off, any help would be appreciated thanx joe Link to comment Share on other sites More sharing options...
ScORTED Posted September 23, 2006 Share Posted September 23, 2006 simplest - get a rag and work it between the handle and the card... the winder mech has a splined end and the handle has a circlip holding it on - same as a drvice shaft, working a rag back and forwards will release it careful not to loose the clip though Link to comment Share on other sites More sharing options...
kevjns Posted September 23, 2006 Share Posted September 23, 2006 simplest - get a rag and work it between the handle and the card... the winder mech has a splined end and the handle has a circlip holding it on - same as a drvice shaft, working a rag back and forwards will release it careful not to loose the clip though ha ha year use a rag make it thin tho there a pane in the arse them but bit of time and you will get there Link to comment Share on other sites More sharing options...
AndyCanning Posted September 23, 2006 Share Posted September 23, 2006 sit in the back seat with the doors shut and pull the thing towards you quite hard, when it starts to come away from the door use a flatheaded scredriver and then find the clip and use another screwdriver to undo the clip Link to comment Share on other sites More sharing options...
Joe Posted September 23, 2006 Author Share Posted September 23, 2006 cheers dudes thanx for the filter too andy, its nice, not to keen on the sound though, but an exhaust should sort that al out sprayed the handles too, im very proud of myslef joe Link to comment Share on other sites More sharing options...
AndyCanning Posted September 23, 2006 Share Posted September 23, 2006 cheers dudes thanx for the filter too andy, its nice, not to keen on the sound though, but an exhaust should sort that al out sprayed the handles too, im very proud of myslef joe ah so you have got it now matey... like i said the bracket is there aswell.. send us a picture so i know its in right... do you smooth the handle down or not mate as it looks better when you do Link to comment Share on other sites More sharing options...
Joe Posted September 25, 2006 Author Share Posted September 25, 2006 nope didnt smooth them as cudnt be aresd, where does that bracket bolt on ot?i left the lower bit of my standard air box in, then bolted onto that, very stable n no trouble, i love the sound now, i pushed the revs up high and its nicecheers Link to comment Share on other sites More sharing options...
AndyCanning Posted September 25, 2006 Share Posted September 25, 2006 nope didnt smooth them as cudnt be aresd, where does that bracket bolt on ot?i left the lower bit of my standard air box in, then bolted onto that, very stable n no trouble, i love the sound now, i pushed the revs up high and its nicecheers the bolt hanget thing goes in the place on the front of the head .. like below does that help Link to comment Share on other sites More sharing options...
Joe Posted September 27, 2006 Author Share Posted September 27, 2006 it dont help that much, urs looks bettr tho!? where is it bolted onto lol/ Link to comment Share on other sites More sharing options...
AndyCanning Posted September 27, 2006 Share Posted September 27, 2006 it dont help that much, urs looks bettr tho!? where is it bolted onto lol/ look at oil cap and just below there, there is a bolt screwed in to the head... that is the black bit with the air filter... Link to comment Share on other sites More sharing options...
