seangti Posted September 26, 2006 Share Posted September 26, 2006 i have 1.8 Escort gti . Iv been offerd some mk2 mondeo 2l calipers ,dics & pads for free wil these go str8 on or do i need the carriers as well ,or do i use the calipers and buy new rs2k dics &pads Link to comment Share on other sites More sharing options...
PeeWee Posted September 26, 2006 Share Posted September 26, 2006 Ask trig or carl123456787 as i think they both will have all the info you need, from what i know theres some minor work but they will go on Link to comment Share on other sites More sharing options...
SaMMy125 Posted September 26, 2006 Share Posted September 26, 2006 Ask trig or carl123456787 as i think they both will have all the info you need, from what i know theres some minor work but they will go on will need mondeo calipers, carriers, pads, carrier bolts, but dont dont dont use the mondeo discs wrong offset, use escort rs2000/xr3i 130 discs 2 fit u will need 2 drill the holes in ur hubs 2mm bigger and use some washers or cut the mondeo bolts down, very very easy 2 fit, and the 2.0 mondeo calipers and pads r bigger than the rs2000 one, by a little bit Link to comment Share on other sites More sharing options...
seangti Posted September 28, 2006 Author Share Posted September 28, 2006 2 fit u will need 2 drill the holes in ur hubs 2mm bigger and use some washers or cut the mondeo bolts down, very very easy 2 fit, and the 2.0 mondeo calipers and pads r bigger than the rs2000 one, by a little bit cheers for advice imight aswel go 4 the complete rs2k setup then ,will i still need rs2k carriers?or can i use me standards 1s Link to comment Share on other sites More sharing options...
SaMMy125 Posted September 28, 2006 Share Posted September 28, 2006 2 fit u will need 2 drill the holes in ur hubs 2mm bigger and use some washers or cut the mondeo bolts down, very very easy 2 fit, and the 2.0 mondeo calipers and pads r bigger than the rs2000 one, by a little bit cheers for advice imight aswel go 4 the complete rs2k setup then ,will i still need rs2k carriers?or can i use me standards 1s yea man if ur gona go for the rs2k fronts use the calipers, carriers and bolts then u dont have 2 drill ur hubs Link to comment Share on other sites More sharing options...
