blakscort Posted February 5, 2003 Share Posted February 5, 2003 do u get problems with yellow gunky stuff in your breather pipes??if so wats the best way of cleaning it all out Link to comment Share on other sites More sharing options...
McRic Posted February 5, 2003 Share Posted February 5, 2003 think you need to stop worrying bout the pipes and find out where the waters getting in mate Link to comment Share on other sites More sharing options...
Chrissyboy Posted February 5, 2003 Share Posted February 5, 2003 aint that the oil?? and it aint good if its that colour Link to comment Share on other sites More sharing options...
blakscort Posted February 5, 2003 Author Share Posted February 5, 2003 ive had this prob with all my cars??? Link to comment Share on other sites More sharing options...
McRic Posted February 5, 2003 Share Posted February 5, 2003 gunk usually means you're getting water into your oil mate, don't do it too much good Link to comment Share on other sites More sharing options...
blakscort Posted February 5, 2003 Author Share Posted February 5, 2003 where would be the best place to check to try and cure it?? Link to comment Share on other sites More sharing options...
McRic Posted February 5, 2003 Share Posted February 5, 2003 rocker cover gasket Link to comment Share on other sites More sharing options...
Paulo Posted February 5, 2003 Share Posted February 5, 2003 Original ford anti-freeze is yellow. try flushin the system as u do when u change coolant. Link to comment Share on other sites More sharing options...
McRic Posted February 5, 2003 Share Posted February 5, 2003 Original ford anti-freeze is yellow. try flushin the system as u do when u change coolant. anti-freeze aint gunky though Link to comment Share on other sites More sharing options...
furry Posted February 5, 2003 Share Posted February 5, 2003 this is cos of yr crank case breathers are blocked, remove all the pipes from the rocker cover inc the one on the right hand rear. clean them all out and flush the oil out and replace with new. Link to comment Share on other sites More sharing options...
Paulo Posted February 5, 2003 Share Posted February 5, 2003 furry am i right in thinkin this is the coolant system. and what is a "breather". its one of those things i have never understood. Link to comment Share on other sites More sharing options...
blakscort Posted February 6, 2003 Author Share Posted February 6, 2003 i`ll try that furry and see what happens. also i wanted to get my sump cleaned and a mekanic said not to bother as it`ll keep leaking once a new gasket is fitted? is this true anyone?? Link to comment Share on other sites More sharing options...
furry Posted February 6, 2003 Share Posted February 6, 2003 breather system is for crank case emissions. i did the sump gasket on my rst 5 times before giving up and giving it to ford!!! it will seal again but only if the tech knows what he's doing Link to comment Share on other sites More sharing options...
sime73 Posted February 6, 2003 Share Posted February 6, 2003 sounds like the old cvh sludge from engines that have not had regular oil changes imo Link to comment Share on other sites More sharing options...
blakscort Posted February 6, 2003 Author Share Posted February 6, 2003 ive done the oil 3 times since july as i had a new cam put in? Link to comment Share on other sites More sharing options...
