Chicane16v Posted March 23, 2009 Share Posted March 23, 2009 When buying a new set of alloys, can i reuse my bolts?Or do i need to make sure the alloys come with theirs? Sorry for the very ammutre question Link to comment Share on other sites More sharing options...
charlie74 Posted March 23, 2009 Share Posted March 23, 2009 if you have alloys fitted atm then you can reuse the bolts,, if you have steels then you need the bolts,, this is mainly due to the taper/shoulder on the head of the bolts being at the correct angle and size to fit,, from what ive been led to belive, steel wheel bolts are slightly smaller and can slowly chew up alloy bolt holes,, Link to comment Share on other sites More sharing options...
Chicane16v Posted March 23, 2009 Author Share Posted March 23, 2009 Thank you Link to comment Share on other sites More sharing options...
bluliz Posted March 23, 2009 Share Posted March 23, 2009 if you have alloys fitted atm then you can reuse the bolts,, if you have steels then you need the bolts,, this is mainly due to the taper/shoulder on the head of the bolts being at the correct angle and size to fit,, from what ive been led to belive, steel wheel bolts are slightly smaller and can slowly chew up alloy bolt holes,, I think you need to learn the difference between a Nut and a Bolt. You need a set of Alloy Wheel Nuts, if you are using Ford wheels then get a set of genuine Ford alloy wheels nuts. If you are going aftermarket check to see if the Ford ones are right of it you need the alloy specific ones. Link to comment Share on other sites More sharing options...
motorheid Posted March 29, 2009 Share Posted March 29, 2009 i was going to ask same question as i have a set of orion mk2 ghia alloys for my escort and was wondering which wheel nuts to use? where would i get a set of ford alloy wheel nuts from? Link to comment Share on other sites More sharing options...
Craig855S Posted March 29, 2009 Share Posted March 29, 2009 scrapyards! the cost of 16 nuts fro ford is scary. most scrapyards should have them in a drawer somewhere,or on the cars Link to comment Share on other sites More sharing options...
