foxdie Posted May 26, 2009 Author Share Posted May 26, 2009 i fixed the problem by the way. Well.. what was the fix.. and cause!? Not sure on the cause. I basically took the thing apart. Remvoed the cmos battery. Checked at the power connections. re-applied the thermal paste on CPU. Gave it good clean. Otherwise i didn't actually do anything. When booted, i set the clocks striaght back to the old ones. Oh, and i manually set the voltage this time, instead of leaving it on auto, also gave the Northbridge +0.2v too to hopefully compensate for the 50% increase in FSB. And my memory is rated at 2.3v, so had to give that plus 0.4v to get the timings. Its running a little hotter than i'd want... but within safe levels. Link to comment Share on other sites More sharing options...
Stu Posted May 26, 2009 Share Posted May 26, 2009 Those 65nm chips run too hot for me This is where my Q9300 sits: http://i42.tinypic.com/2e15f1k.jpg Link to comment Share on other sites More sharing options...
Simonez Posted May 26, 2009 Share Posted May 26, 2009 was goin to say reapply thermal grease and resit the Heatsink, what thermal stuff you use? i used AC5 and mx2 paste depending which is nearer and my Q6600 idles around 19-20 and doesnt go above 40 at full whack, at stock speeds gets even lower with the old Aircon on! glad ya sorted it paul! Link to comment Share on other sites More sharing options...
