foxdie Posted May 21, 2009 Share Posted May 21, 2009 I've been running my Q6600 at 3.2ghz for several months. set at 8 x 400mhz with memory strapped to 1:1. Voltages were left on auto as my mobo suffers from terrible vdroop. Its gigabyte P35 mobo. Turn it on today and it booted at 8 x 266. which was weird, so i went straight into bios to check the settings and all my settings were there as above. So i thought it must be a fluke, so i rebooted again. and again it booted up at 8 x 266. So i defaulted it all. Boots up at 9 x 266 which is the correct defualt clocks for my cpu. So then i went back into bios to put my proven OC specs in. 8 x 400 etc etc. rebooted again boots back up at 8 x266. It wont even except any increase/or decrease in CPU clock It appears either my mobo, or cpu is no longer responding to cmos changes to the CPU clock. i can change the multiplier, but the changes to the Clock do not take effect - it stays like its locked to 266. Your help with this overly frustrating problem is much apprecieated. Link to comment Share on other sites More sharing options...
trickydicky Posted May 21, 2009 Share Posted May 21, 2009 have you tried another CMOS battery? Looks like it is forgetting some settings. Link to comment Share on other sites More sharing options...
The Bishop Posted May 22, 2009 Share Posted May 22, 2009 have you tried another CMOS battery? Looks like it is forgetting some settings. +1. was gonna suggest that. do your settings revert to default when you go back into CMOS after youve changed to the overclocked values? Link to comment Share on other sites More sharing options...
foxdie Posted May 22, 2009 Author Share Posted May 22, 2009 have you tried another CMOS battery? Looks like it is forgetting some settings. +1. was gonna suggest that. do your settings revert to default when you go back into CMOS after youve changed to the overclocked values? Its not the CMOS battery - the settings are being saved but are being ignored. Link to comment Share on other sites More sharing options...
Stu Posted May 22, 2009 Share Posted May 22, 2009 The CMOS battery doesn't settings these days, it's purely for the real-time clock (RTC)... BIOS settings are flashed to EEPROM.. This is more than likely caused by something becoming 'tired' on your motherboard.. a bad cap or something which is reducing the capabilities of the voltage regulators on the board which is stopping you overclocking as far as you did before.. Link to comment Share on other sites More sharing options...
Gonzo0 Posted May 22, 2009 Share Posted May 22, 2009 Hve u disabled all the usuall stuff such as Intel Speedstep etc. Make sure you disable all safety functions. Then try overclocking in small increments, testing the clock in Orthos and keeping an eye on the clocks in CPU-Z. If the clocks drop when the test is running then something is resetting your clocks back to default. Link to comment Share on other sites More sharing options...
foxdie Posted May 22, 2009 Author Share Posted May 22, 2009 Hve u disabled all the usuall stuff such as Intel Speedstep etc. Make sure you disable all safety functions. Then try overclocking in small increments, testing the clock in Orthos and keeping an eye on the clocks in CPU-Z. If the clocks drop when the test is running then something is resetting your clocks back to default. It wont post at anything above standard. Link to comment Share on other sites More sharing options...
andaba Posted May 22, 2009 Share Posted May 22, 2009 Can you underclock it? Link to comment Share on other sites More sharing options...
foxdie Posted May 22, 2009 Author Share Posted May 22, 2009 Can you underclock it?yes, but only by reducing the multiplier Link to comment Share on other sites More sharing options...
Gadge Posted May 22, 2009 Share Posted May 22, 2009 See if there is any updates to the motherboard / reflash the bios it wont hurt anything by giving it ago. altenatively it could be a safety feature and its underclocking its self because of your powersupply isnt putting out the correct voltage. Link to comment Share on other sites More sharing options...
andaba Posted May 22, 2009 Share Posted May 22, 2009 Well if it doesn't underclock and keep the settings then I'd put it down to a fooked component - something that's sending the voltages haywire? Link to comment Share on other sites More sharing options...
Hezz Posted May 22, 2009 Share Posted May 22, 2009 i understand the overclocking idea but have no idea what you are quoting! Link to comment Share on other sites More sharing options...
Simonez Posted May 25, 2009 Share Posted May 25, 2009 what temps ya q6600 at paul? on standard speeds etc? what cooler you use also? Link to comment Share on other sites More sharing options...
foxdie Posted May 25, 2009 Author Share Posted May 25, 2009 what temps ya q6600 at paul? on standard speeds etc? what cooler you use also? i fixed the problem by the way. @3.2ghz (400x8) on a 20+ ambient day: CPU cooler artic freezer 7. Max temps under 4x100% stress tests CPU temp = 63'cSystem temp 50'cGTX285 temp 70'cCore1 = 71'cCore2 = 71'cCore3 = 64'cCore4 = 63'c Thats with Silverstone L13 HTPC case with i would say 10% ventatlation. 2x80mm fans ventalating to rear, with about 2cm rear access around back and sides. Link to comment Share on other sites More sharing options...
Stu Posted May 26, 2009 Share Posted May 26, 2009 (edited) i fixed the problem by the way. Well.. what was the fix.. and cause!? Edited May 26, 2009 by Stu Link to comment Share on other sites More sharing options...
