Chris O Posted June 15, 2009 Share Posted June 15, 2009 A bit of a long shot here, I have acquired a set of BIG brakes and need to work out some way of fitting them (without massive amounts of spacing). How much brake clearance is there between the back of the a RS 7 alloy and a standard brake caliper. Link to comment Share on other sites More sharing options...
ScORTED Posted June 15, 2009 Share Posted June 15, 2009 you won't get much bigger than 280s + moderately sized calipers under 17" rs7s... how big are your brakes? Link to comment Share on other sites More sharing options...
shawdreamer Posted June 15, 2009 Share Posted June 15, 2009 A bit of a long shot here, I have acquired a set of BIG brakes and need to work out some way of fitting them (without massive amounts of spacing). How much brake clearance is there between the back of the a RS 7 alloy and a standard brake caliper. why not just "dry test" the fitment, dont go as far as disconnecting your existing calipers from the brake lines, just remove them from the spindle carrier/hub and suspend them safely out the way so you can fit the new calipers and in its place before trying the wheel over it? suppose it depends on wether you have all the relavant parts to hand but... seems like the only way to be 100% sure to me? Link to comment Share on other sites More sharing options...
Chris O Posted June 15, 2009 Author Share Posted June 15, 2009 (edited) A bit of a long shot here, I have acquired a set of BIG brakes and need to work out some way of fitting them (without massive amounts of spacing). How much brake clearance is there between the back of the a RS 7 alloy and a standard brake caliper. why not just "dry test" the fitment, dont go as far as disconnecting your existing calipers from the brake lines, just remove them from the spindle carrier/hub and suspend them safely out the way so you can fit the new calipers and in its place before trying the wheel over it? suppose it depends on wether you have all the relavant parts to hand but... seems like the only way to be 100% sure to me? I have got hold of some 305mm discs with 4 pot brembo's that were fitted to a st170. I have trial fitted them under my 16" 6.5J Mondeo alloys and they will just fit but only with a manic amount of spacing. I was hoping that a set of rs7's would possibly help house them, if not I would be forced into using some comps. Edited June 15, 2009 by Chris O Link to comment Share on other sites More sharing options...
ScORTED Posted June 15, 2009 Share Posted June 15, 2009 rs7s are shite for clearance you can't get 300mm discs + mondeo calipers under them I'm selling my very lovely MO's ;) Link to comment Share on other sites More sharing options...
Chris O Posted June 15, 2009 Author Share Posted June 15, 2009 rs7s are shite for clearance you can't get 300mm discs + mondeo calipers under them That is quite shocking. When I had a fiesta zetec-s most people ran 300mm behind the standard 15's!! Link to comment Share on other sites More sharing options...
SLEEMAN Posted June 15, 2009 Share Posted June 15, 2009 300mm behind 15's? did they use a smaller caliper then? Link to comment Share on other sites More sharing options...
ScORTED Posted June 15, 2009 Share Posted June 15, 2009 rs7s are shite for clearance you can't get 300mm discs + mondeo calipers under them That is quite shocking. When I had a fiesta zetec-s most people ran 300mm behind the standard 15's!! 300mm do fit inside 15s, however i've not seen any that do with mondeo calipers... I've heard people claim to get the mondeo mk3 calipers under 15s but never seen a picture Link to comment Share on other sites More sharing options...
Chris O Posted June 15, 2009 Author Share Posted June 15, 2009 (edited) 300mm behind 15's? did they use a smaller caliper then? They shaved a small amount off the back of the caliper and have no balancing weights there to run 300mm. I ran 278mm mondeo's on my zetec-s no problems with clearance to spare (cleared the balancing weights). http://i82.photobucket.com/albums/j279/ChrisO2006/DSC00745.jpg Edited June 16, 2009 by Chris O Link to comment Share on other sites More sharing options...
Chris O Posted June 16, 2009 Author Share Posted June 16, 2009 (edited) rs7s are shite for clearance you can't get 300mm discs + mondeo calipers under them That is quite shocking. When I had a fiesta zetec-s most people ran 300mm behind the standard 15's!! 300mm do fit inside 15s, however i've not seen any that do with mondeo calipers... I've heard people claim to get the mondeo mk3 calipers under 15s but never seen a picture Just is the word. The wheel MUST be perfect because it is VERY close...http://i244.photobucket.com/albums/gg27/joe_herne/DSC00176.jpghttp://i244.photobucket.com/albums/gg27/joe_herne/DSC00178.jpg I never really like it because it can't be good for cooling but it can be done tho. Edited June 16, 2009 by Chris O Link to comment Share on other sites More sharing options...
RyanML Posted June 16, 2009 Share Posted June 16, 2009 rs7s are shite for clearance you can't get 300mm discs + mondeo calipers under them I'm selling my very lovely MO's ;) yes you can http://img17.imageshack.us/img17/5191/img0630h.jpg aint much room tho. Link to comment Share on other sites More sharing options...
shawdreamer Posted June 16, 2009 Share Posted June 16, 2009 http://i244.photobucket.com/albums/gg27/joe_herne/DSC00178.jpg I never really like it because it can't be good for cooling but it can be done tho. feck me, you hit a nasty unseen pothole or clip a kerb enough to buckle a alloy (not as hard as you'd think to accomplish) your gonna know about it in a serious way, wont just be just replacing a alloy, that close even a slight buckle will likely rip the caliper clean off the spindle carrier or shatter the alloy totally in the process Link to comment Share on other sites More sharing options...
ScORTED Posted June 16, 2009 Share Posted June 16, 2009 rs7s are shite for clearance you can't get 300mm discs + mondeo calipers under them I'm selling my very lovely MO's ;) yes you can http://img17.imageshack.us/img17/5191/img0630h.jpg aint much room tho. i stand corrected, i did know someone who oculdn't get those brakes under the diamond cut ones, but i tohught the castings were the same and 300mm brakes under 15s FTW!... but the clearance was very close under the standard mondeo 16s on my mondeo??? Link to comment Share on other sites More sharing options...
