16Vrhys Posted November 2, 2010 Share Posted November 2, 2010 another way ive heard is a sized socket same size as bearing and use that to tap it in , can the grease be used to help with installation or is that packed after? Link to comment Share on other sites More sharing options...
eetaylog Posted November 2, 2010 Author Share Posted November 2, 2010 another way ive heard is a sized socket same size as bearing and use that to tap it in , can the grease be used to help with installation or is that packed after? or as i said above, use the old bearings (instead of socket that you mentioned above) to tap them in as theyre exactly the same size that you need. Link to comment Share on other sites More sharing options...
etrebus Posted November 4, 2010 Share Posted November 4, 2010 ]another way ive heard is a sized socket same size as bearing and use that to tap it in , can the grease be used to help with installation or is that packed after? ]no fit bearing races clean and dry grease bearings before fitting properly pack bearings with grease force it in all parts of the bearing by pushing it in with a finger messy but essential. grease races and put a little bit in the space between bearings but do not fill up space (over pack) cleanlines is important Link to comment Share on other sites More sharing options...
