Escort_Kid Posted May 28, 2011 Share Posted May 28, 2011 Well as title really, just out of interest, would it be possible to convert a 5 door front seat using any donor parts from a 3 door seat to be like a 3 door seat as in could you make it so it flips forward as it would in a 3 door? Thanks all :cheers: Link to comment Share on other sites More sharing options...
lee grout Posted May 28, 2011 Share Posted May 28, 2011 Why not just put in seats from a 3 door! Link to comment Share on other sites More sharing options...
shawdreamer Posted May 28, 2011 Share Posted May 28, 2011 Well as title really, just out of interest, would it be possible to convert a 5 door front seat using any donor parts from a 3 door seat to be like a 3 door seat as in could you make it so it flips forward as it would in a 3 door? Thanks all :cheers: both types have the same base and hinge points. only the rear supports are different. but. If its cos you like a particular type of seat found in 5drs but want it in your 3dr... Its easier to simply strip the covers and foam off the 5dr seats and put it onto the 3dr frames, Its really THAT simple a operation. Link to comment Share on other sites More sharing options...
Escort_Kid Posted May 28, 2011 Author Share Posted May 28, 2011 Well as title really, just out of interest, would it be possible to convert a 5 door front seat using any donor parts from a 3 door seat to be like a 3 door seat as in could you make it so it flips forward as it would in a 3 door? Thanks all :cheers: both types have the same base and hinge points. only the rear supports are different. but. If its cos you like a particular type of seat found in 5drs but want it in your 3dr... Its easier to simply strip the covers and foam off the 5dr seats and put it onto the 3dr frames, Its really THAT simple a operation. Yeah thats what I was thinking may be the case, ok cool cheers mate Link to comment Share on other sites More sharing options...
shawdreamer Posted May 28, 2011 Share Posted May 28, 2011 Well as title really, just out of interest, would it be possible to convert a 5 door front seat using any donor parts from a 3 door seat to be like a 3 door seat as in could you make it so it flips forward as it would in a 3 door? Thanks all :cheers: both types have the same base and hinge points. only the rear supports are different. but. If its cos you like a particular type of seat found in 5drs but want it in your 3dr... Its easier to simply strip the covers and foam off the 5dr seats and put it onto the 3dr frames, Its really THAT simple a operation. Yeah thats what I was thinking may be the case, ok cool cheers mate all you'll need is some needle and thread to sew back some elastic straps you'll need to cut to get the covers off (again not a big issue) and a can of spray upholstery adhesive to resit the fabric to the foam. put it this way. My current motor has wingbacks in it out a 5dr (mine being a 3dr) and if I hadn't decided to make the wingbacks half leather while I was doing it I would have been done in a morning. Link to comment Share on other sites More sharing options...
escort-ross Posted June 2, 2011 Share Posted June 2, 2011 I did it years ago with mine ... I have full leather ghiaX seats in my 3 door. Be prepared to cut your fingers multiple times but its not too hard to do, just replace the covers onto the 3 door frames and the cut the slot in the side for the handle Link to comment Share on other sites More sharing options...
