martinw17 Posted March 20, 2012 Share Posted March 20, 2012 Hi guys I have a 1.4 cvh escort mk 6 to start it in morning u have to press throttle and if u let off it will cit out so u have to feather throttle for about 10 to 15 seconds then it will idol ok after what u recon could be thanks use to be fine at starting thanks guys Link to comment Share on other sites More sharing options...
JC Posted March 20, 2012 Share Posted March 20, 2012 Cleaned the idle control valve. at a guess? Link to comment Share on other sites More sharing options...
martinw17 Posted March 20, 2012 Author Share Posted March 20, 2012 Cleaned the idle control valve. at a guess?Thanks know this is silly but were about is it mate its a cvh 1.4 injection mk 6 escort thanks again Link to comment Share on other sites More sharing options...
etrebus Posted March 21, 2012 Share Posted March 21, 2012 sounds like it may be have a lean mixture .poss have air leak, did it happen suddenly? Link to comment Share on other sites More sharing options...
martinw17 Posted March 25, 2012 Author Share Posted March 25, 2012 sounds like it may be have a lean mixture .poss have air leak, did it happen suddenly?Yerr after changed gearbox mate Link to comment Share on other sites More sharing options...
scottg17 Posted March 25, 2012 Share Posted March 25, 2012 My guess is youve got a vacuum hose off of somewhere Link to comment Share on other sites More sharing options...
etrebus Posted March 26, 2012 Share Posted March 26, 2012 sounds like it may be have a lean mixture .poss have air leak, did it happen suddenly?Yerr after changed gearbox matethen im guessing its the pipe that runs from inlet manifold to crancase breather on front of engine under exhaust manifold . worth a look Link to comment Share on other sites More sharing options...
martinw17 Posted March 30, 2012 Author Share Posted March 30, 2012 sounds like it may be have a lean mixture .poss have air leak, did it happen suddenly?Yerr after changed gearbox matethen im guessing its the pipe that runs from inlet manifold to crancase breather on front of engine under exhaust manifold . worth a look tar mate will jack car up tomoz and have a look will it be same on cvh engine thanks bud Link to comment Share on other sites More sharing options...
etrebus Posted April 2, 2012 Share Posted April 2, 2012 sounds like it may be have a lean mixture .poss have air leak, did it happen suddenly?Yerr after changed gearbox matethen im guessing its the pipe that runs from inlet manifold to crancase breather on front of engine under exhaust manifold . worth a look tar mate will jack car up tomoz and have a look will it be same on cvh engine thanks buduh no just noticed that lol still worth checking all pipes though Link to comment Share on other sites More sharing options...
martinw17 Posted April 10, 2012 Author Share Posted April 10, 2012 carnt seem to c anything lads lol its wired baffled me when its warm start up fine but when cold will only start when give it some gas n have to feather throttle for few seconds 4 it to idol n after about 3000 rpm at a guess rev counter dnt work it kind of sticks n then come back off but its not pedal sticking or owt any one got any more ideas thanks again chaps carnt seem to c anything lads lol its wired baffled me when its warm start up fine but when cold will only start when give it some gas n have to feather throttle for few seconds 4 it to idol n after about 3000 rpm at a guess rev counter dnt work it kind of sticks n then come back off but its not pedal sticking or owt any one got any more ideas thanks again chaps Link to comment Share on other sites More sharing options...
Georgio Posted April 11, 2012 Share Posted April 11, 2012 If it starts fine when warm,but difficult when cold,it could be the coolant sensor.This informs the ECU if the engine is cold and enrichens mixture.It is in the back of the engine,on the inlet manifold,between runners 3 and 4.It is a bit awkward place.Try to unplug it and start the engine.From what you describe,it seems like the ECU doesn't enrich the mixture to warm the engine faster.It's like running a cold carbureted engine,with the chock off. Link to comment Share on other sites More sharing options...
martinw17 Posted April 11, 2012 Author Share Posted April 11, 2012 If it starts fine when warm,but difficult when cold,it could be the coolant sensor.This informs the ECU if the engine is cold and enrichens mixture.It is in the back of the engine,on the inlet manifold,between runners 3 and 4.It is a bit awkward place.Try to unplug it and start the engine.From what you describe,it seems like the ECU doesn't enrich the mixture to warm the engine faster.It's like running a cold carbureted engine,with the chock off.do then start it from cold u mean and if it starts ok would it be a case of getting a new sensor thanks again mate Link to comment Share on other sites More sharing options...
Georgio Posted April 12, 2012 Share Posted April 12, 2012 If it starts fine when warm,but difficult when cold,it could be the coolant sensor.This informs the ECU if the engine is cold and enrichens mixture.It is in the back of the engine,on the inlet manifold,between runners 3 and 4.It is a bit awkward place.Try to unplug it and start the engine.From what you describe,it seems like the ECU doesn't enrich the mixture to warm the engine faster.It's like running a cold carbureted engine,with the chock off.do then start it from cold u mean and if it starts ok would it be a case of getting a new sensor thanks again mate Yes.Excuse my English. Disconnect the sensor and try when the engine is cold.If it starts and idles better than with the sensor connected,then chances are that the sensor is not working as it should.If I understand correct,you said that when the engine is warm,and you try to start it,it starts and idles fine.Am I correct? Link to comment Share on other sites More sharing options...
martinw17 Posted April 12, 2012 Author Share Posted April 12, 2012 If it starts fine when warm,but difficult when cold,it could be the coolant sensor.This informs the ECU if the engine is cold and enrichens mixture.It is in the back of the engine,on the inlet manifold,between runners 3 and 4.It is a bit awkward place.Try to unplug it and start the engine.From what you describe,it seems like the ECU doesn't enrich the mixture to warm the engine faster.It's like running a cold carbureted engine,with the chock off.do then start it from cold u mean and if it starts ok would it be a case of getting a new sensor thanks again mate Yes.Excuse my English. Disconnect the sensor and try when the engine is cold.If it starts and idles better than with the sensor connected,then chances are that the sensor is not working as it should.If I understand correct,you said that when the engine is warm,and you try to start it,it starts and idles fine.Am I correct?hi if its like a single wire connecter quite far down tryed unpluging that n still no joy mate thanks Link to comment Share on other sites More sharing options...
Georgio Posted April 12, 2012 Share Posted April 12, 2012 (edited) Yeap...that's the one...you must pull it firmly,since this has a safety lug.But not from the wire,pull the connector.It feels like it is gonna come off,but it doesn't!Take care of your hand,when it comes off,you can hurt it on the firewall,bolts in the surround area....well,I did.lol. Edited April 12, 2012 by Georgio Link to comment Share on other sites More sharing options...
