EscortGTi_ Posted April 12, 2012 Share Posted April 12, 2012 Hi There! I hope someone can help me on this.... I have an Escort GTI and a few days ago my CD player blew & now doesnt work., Since then, the clock has stopped working but still lights up and the cigarette lighter bit doesn't work either I have checked all the fuses and non have blown :S I hope that made sense :/ If anyone can give me some advise i would really appreciate it. Many Thanks,Ange Link to comment Share on other sites More sharing options...
Naylor2006 Posted April 12, 2012 Share Posted April 12, 2012 (edited) Man that's an odd one, could be bad ground, how bad was the blow? Could have dislodged a wire? Have you had a good look at the loom? Edited April 12, 2012 by Naylor2006 Link to comment Share on other sites More sharing options...
MCCORNY11 Posted April 12, 2012 Share Posted April 12, 2012 would check your fuses again some can look like they haven't blown but really have Link to comment Share on other sites More sharing options...
Naylor2006 Posted April 12, 2012 Share Posted April 12, 2012 would check your fuses again some can look like they haven't blown but really have True but he is getting some power? They all run from the same fuse IIRC, they don't have a relay as well for any reason? To be honest if the radio blew cause it shorted out or something it could have knackered the clock and lighter somewhat. Link to comment Share on other sites More sharing options...
MCCORNY11 Posted April 12, 2012 Share Posted April 12, 2012 does the lights not run off separate circuit. Link to comment Share on other sites More sharing options...
etrebus Posted April 15, 2012 Share Posted April 15, 2012 does the lights not run off separate circuit.yes they come off the side light circuit as above check fuses again fuse 29 and it should be 15 amp(blue) Link to comment Share on other sites More sharing options...
