ZeTeC101 Posted May 12, 2012 Share Posted May 12, 2012 I have a escort mk6 1.6 zetec e and have run into a big problem, i was riding one day and all of a sudden it would jerk every now and then almost as it was fuel starvation,so i put new fuel pump in and the problem was still there but getting worse. Then it would start cutting out, and the rev counter jumps irradiculy, if you turn the ignition off and turn it back on without starting the engine its fine the rev counter.I thought it might be the coilpack so replaced that and problem still persists,i thought maybe it was computer box so i got another one and problem still the same, now what i cant understand is the longer i leave the car off the more i can drive before it starts to missfire and jerk and cut_out then the rev counter jumps all over again,almost like problem happens when hot. Please help me. thank you I dont know if this is right but i unplugged icv and engine cuts out and they say if that happens that means its not broken? Link to comment Share on other sites More sharing options...
JC Posted May 12, 2012 Share Posted May 12, 2012 if you unplug the idel control valve then it will cut out I would get it diagnosed at a garage If i was a betting man, my money would look at the MAF Link to comment Share on other sites More sharing options...
ZeTeC101 Posted May 12, 2012 Author Share Posted May 12, 2012 I was thinking about MAF,just the rev counter jumping around makes me think its electrical? Link to comment Share on other sites More sharing options...
Naylor2006 Posted May 12, 2012 Share Posted May 12, 2012 I'm with JC and have it diagnosed, jumping rev count is nuts, bad wiring can cause some wierd stuff to happen, when the live wire came out the back of my clock and touched the metal chassis my gauges went nuts. I was gonna say fecked ECU but I assume that's what you mean by computer box. You could drive without the MAF plugged in but it's not recommended but you might find out if it's the MAF. Link to comment Share on other sites More sharing options...
duffa Posted May 13, 2012 Share Posted May 13, 2012 had a similar problem a few years back ..try the fuel pump relay on the fuse box mine had a dry solder and the problem was very intermittent Link to comment Share on other sites More sharing options...
ZeTeC101 Posted May 14, 2012 Author Share Posted May 14, 2012 Thanks guys will try the suggested out, so if i ride without the maf plugged in and it still happens to do it its not the maf? just one extra thing to cross of that could be problem.I could get my hands on a 2lt maf would that work on the 1.6? Link to comment Share on other sites More sharing options...
ZeTeC101 Posted May 14, 2012 Author Share Posted May 14, 2012 Ok today i was checking all the earths and wires on the loom and would seem whenever i bumped near the coilpack it would cut_out.So further investigation there is a pipe that is under the coilpack thats not to long(i think it connects from head to block, kinda like a breathger pipe) it was pinched and i then cut it small and connected it and problem seems to be sorted i hope.Could that have been the issue???????? Link to comment Share on other sites More sharing options...
Naylor2006 Posted May 14, 2012 Share Posted May 14, 2012 Ok today i was checking all the earths and wires on the loom and would seem whenever i bumped near the coilpack it would cut_out.So further investigation there is a pipe that is under the coilpack thats not to long(i think it connects from head to block, kinda like a breathger pipe) it was pinched and i then cut it small and connected it and problem seems to be sorted i hope.Could that have been the issue???????? What round the back of the inlet manifold to the front of the bottom end? Link to comment Share on other sites More sharing options...
