WelshWizard Posted September 12, 2012 Share Posted September 12, 2012 I have an Escort Gti and when I bought it it had the common problem with the key/lock where it wouldn't turn to unlock it very well so I bought and had fitted a remote control unit for the central lock and that's been working fine. Problem is while it was locked someone opened it with the key and it set the alarm off and I can't deactivate it as I can't turn the key to unlock the door. I've tried disconnecting the battery for a while but that doesn't do anything. Someone said I need to get a new lock or barrel or something, I'll have a go at fitting it myself but how much of a ball-ache is it to do? Also I don't have the 'red' key, will that be a problem? Link to comment Share on other sites More sharing options...
scottybo Posted September 12, 2012 Share Posted September 12, 2012 lock it and unlock it with the central locking fob, as soon as u do anything with the car thinking its still locked, the alarm will go off, i had a similar issue with my si Link to comment Share on other sites More sharing options...
Naylor2006 Posted September 13, 2012 Share Posted September 13, 2012 lock it and unlock it with the central locking fob, as soon as u do anything with the car thinking its still locked, the alarm will go off, i had a similar issue with my si Lol, surely he's tried that which makes me wonder already why that hasn't worked. I'm pretty sure there's a guide on here how to fix this barrell problem. Check the 'how to' forum mate, you might be able to fix it without fwarking around with new locks and stuff. Found it for you http://www.escortevolution.co.uk/forums/in...howtopic=143185 Link to comment Share on other sites More sharing options...
WelshWizard Posted September 13, 2012 Author Share Posted September 13, 2012 Lol, surely he's tried that which makes me wonder already why that hasn't worked. I'm pretty sure there's a guide on here how to fix this barrell problem. Check the 'how to' forum mate, you might be able to fix it without fwarking around with new locks and stuff. Yeah I had a look, couldn't find anything though edit: thanks, I found it - and saw you looking at it at the same time Link to comment Share on other sites More sharing options...
Naylor2006 Posted September 13, 2012 Share Posted September 13, 2012 Lol, surely he's tried that which makes me wonder already why that hasn't worked. I'm pretty sure there's a guide on here how to fix this barrell problem. Check the 'how to' forum mate, you might be able to fix it without fwarking around with new locks and stuff. Yeah I had a look, couldn't find anything though edit: thanks, I found it - and saw you looking at it at the same time As long as the barrell is in tact changing the mechanism seems like an easy fix really, you'll be able to pick one up on here from someone who's breaking a car. Link to comment Share on other sites More sharing options...
WelshWizard Posted September 13, 2012 Author Share Posted September 13, 2012 Just tried it, unfortunately the guide is either incomplete or incorrect, the instructions and pictures just don't match up with what's in my car doors. Link to comment Share on other sites More sharing options...
Naylor2006 Posted September 13, 2012 Share Posted September 13, 2012 Just tried it, unfortunately the guide is either incomplete or incorrect, the instructions and pictures just don't match up with what's in my car doors. Surely you can get your door apart enough to inspect the problem though? Link to comment Share on other sites More sharing options...
JAMGTI Posted September 13, 2012 Share Posted September 13, 2012 I think on the ford alarm there is a microswitch on the lock mechanism and a sensor/switch that clips around the lock barrel which is not fitted to the car in the thread. might just need these parts replacing from a scrappie or disconnect the part on the lock barrel so that it doesn't arm if you lock it with the key by mistake. Link to comment Share on other sites More sharing options...
etrebus Posted September 13, 2012 Share Posted September 13, 2012 I think on the ford alarm there is a microswitch on the lock mechanism and a sensor/switch that clips around the lock barrel which is not fitted to the car in the thread. might just need these parts replacing from a scrappie or disconnect the part on the lock barrel so that it doesn't arm if you lock it with the key by mistake.could also try unlocking it from the passenger side as this side is often rarley used so the switch around the lock is usually ok Link to comment Share on other sites More sharing options...
Naylor2006 Posted September 13, 2012 Share Posted September 13, 2012 I think on the ford alarm there is a microswitch on the lock mechanism and a sensor/switch that clips around the lock barrel which is not fitted to the car in the thread. might just need these parts replacing from a scrappie or disconnect the part on the lock barrel so that it doesn't arm if you lock it with the key by mistake.could also try unlocking it from the passenger side as this side is often rarley used so the switch around the lock is usually ok Again lol, I expect hes tried this. Is this an aftermarket alarm system or the stock ford one that keeps going off? Take it apart and post up some pics if your stuck, someone will spot whats wrong im sure. Link to comment Share on other sites More sharing options...
