crazyq Posted November 9, 2012 Share Posted November 9, 2012 - When cold start the engine revs up to 2000 rpm and above. Sometimes drops to 1500 after a few seconds, but often the rev tends to rise to 3000 rpm. Rev decreases when the engine heats at normal. Sometimes happens, even after the engine has warmed up, the rpm to stay in 1500. i must stop the engine and start it again for the idle to sit at normal rpm. - When the engine is warm simply has no power. It revs hard. It has acceleration delay "seems to think what to do." Acceleration is not uniform -On deceleration when the car is in gear the engine has detonation in the exhaust. -Sometimes when headlights and warming are turned on the idle speed drops to 500 rpm and engine shaking, but that rarely happens and often resolved by stopping and starting the engine -I changed ISCV a year ago because idle speed remained above 3000 rpm. The problem was solved but the car still does not accelerate properly. It looks like has 30 HP not 90. What should I change to get rid of these problems? Thank's a lot!!! Excuse my English but I hope you understand what I mean!!!! Link to comment Share on other sites More sharing options...
Stu Posted November 9, 2012 Share Posted November 9, 2012 Before you post a new thread, please use our search system to find out if your question has already been answered. There is a high chance that it already has! Link to comment Share on other sites More sharing options...
scottybo Posted November 12, 2012 Share Posted November 12, 2012 sounds like head gasket failure....or a dicky clutch and a host of other issues Link to comment Share on other sites More sharing options...
james08 Posted November 12, 2012 Share Posted November 12, 2012 What should I change to get rid of these problems? the car? Link to comment Share on other sites More sharing options...
Rockerrob666 Posted November 13, 2012 Share Posted November 13, 2012 What should I change to get rid of these problems? the car?i agree, it sounds like your either gonna have to strip the block and check ancilleries or just try and hide it when trading / selling to get a new motor. RIP another escort Link to comment Share on other sites More sharing options...
scottybo Posted November 16, 2012 Share Posted November 16, 2012 What should I change to get rid of these problems? the car?i agree, it sounds like your either gonna have to strip the block and check ancilleries or just try and hide it when trading / selling to get a new motor. RIP another escort i do not condone hiding problems until the vehicle is sold. its just plain harsh n the guy buying it Link to comment Share on other sites More sharing options...
crazyq Posted December 3, 2012 Author Share Posted December 3, 2012 sounds like head gasket failure....or a dicky clutch and a host of other issues maybe but doesn't lose coolant liquid.and when I remove the cap from the rocker arms out no oil vapor or odor. I always change the oil at 8000 km, Mobil 1 10W30. It loses max. 30 cl in 8000 km.I didn't find a OEM PCV valve, because i want to cange it. Also i want to change the little valve located on the plastic hose from assisted braking. I suspect there's a vacuum problem. Thank you for your opinion Link to comment Share on other sites More sharing options...
sidrick Posted December 3, 2012 Share Posted December 3, 2012 Sounds like an air leak or an air flow meter problem to me. Link to comment Share on other sites More sharing options...
