shenaf Posted April 14, 2013 Share Posted April 14, 2013 Hi i have a 1.6 16v zetec escort and i was wondering if an oil catch tank is worth fitting on a non turbo engine . or is it just something that looks good in the engine bay? Link to comment Share on other sites More sharing options...
Stu Posted April 14, 2013 Share Posted April 14, 2013 No Yes Link to comment Share on other sites More sharing options...
JC Posted April 14, 2013 Share Posted April 14, 2013 If you track the car, or have a K&N then in my opinion worth having Link to comment Share on other sites More sharing options...
Stu Posted April 14, 2013 Share Posted April 14, 2013 If you track the car, or have a K&N then in my opinion worth having What difference does it make? Link to comment Share on other sites More sharing options...
JC Posted April 14, 2013 Share Posted April 14, 2013 If you track the car, or have a K&N then in my opinion worth having What difference does it make? Catches oil. Some tracks require them to be fitted. Link to comment Share on other sites More sharing options...
shenaf Posted April 14, 2013 Author Share Posted April 14, 2013 How easy and what's required to fit them cuz I'm getting a k&n Link to comment Share on other sites More sharing options...
Stu Posted April 14, 2013 Share Posted April 14, 2013 If you track the car, or have a K&N then in my opinion worth having What difference does it make? Catches oil. Some tracks require them to be fitted. Where would the oil go otherwise? Link to comment Share on other sites More sharing options...
Andy 3i Posted April 14, 2013 Share Posted April 14, 2013 I'm guessing that if you run an aftermarket filter but can't/don't use the breather pipe to return back into the inlet I'm guessing the minimal vapour is going to cause an issue? I know that your not meant to let the oil vent to atmosphere for some reason...I believe mot purposes Link to comment Share on other sites More sharing options...
Stu Posted April 14, 2013 Share Posted April 14, 2013 K&N has a hole in it for the breather pipe to go back onto, or at least they used to. Link to comment Share on other sites More sharing options...
Andy 3i Posted April 14, 2013 Share Posted April 14, 2013 Well yes they do, but if a budget Wong pong filter is used without a breather hole, a seperate breather filter can be used. I'm guessing that's what Jc is referring to? So instead of using a little filter, a catch can could theoretically be used to keep the engine sealed. Obviously it makes no performance gains whatsoever and it would make the engine bay even more cluttered. Link to comment Share on other sites More sharing options...
shenaf Posted April 14, 2013 Author Share Posted April 14, 2013 so which pipes would you connect it to i would of though somewhere around the crank ventilation but would you then use the rocker cover hose or the other side of the crank ventilation? Link to comment Share on other sites More sharing options...
