JC Posted June 27, 2013 Share Posted June 27, 2013 power steering pressure switch where is it on a MK6? and how remove? cheers Link to comment Share on other sites More sharing options...
SLEEMAN Posted June 27, 2013 Share Posted June 27, 2013 isn't that on the back of the engine under the inlet manifold by the oil filter? Link to comment Share on other sites More sharing options...
JC Posted June 28, 2013 Author Share Posted June 28, 2013 Not sure, i'll look! cheers Link to comment Share on other sites More sharing options...
demented Posted June 28, 2013 Share Posted June 28, 2013 SLEEMAN is right, it's behind engine just above oil filter. The pressure switch is located in the power steering pipe which runs from the pump and in between the cambelt cover and steering fluid reservoir. I've never removed or had to replace the pressure switch but I assume it can be unscrewed/unbolted.Also assume, when and while removing steering fluid will be lost, may need to drain the system. Link to comment Share on other sites More sharing options...
