bhp soothes me Posted July 3, 2013 Share Posted July 3, 2013 hi guys, just goning to put my 300mm setup on and was wondering where and why do you put copper grease thanks Link to comment Share on other sites More sharing options...
Andy 3i Posted July 3, 2013 Share Posted July 3, 2013 Copper grease on the ears of the pads where they sit in the caliper and a smear on the back, just where the caliper contacts. Helps prevent brake squeal and brakes seizing Link to comment Share on other sites More sharing options...
JC Posted July 3, 2013 Share Posted July 3, 2013 And use new bolts on putting the calipers on Link to comment Share on other sites More sharing options...
etrebus Posted July 3, 2013 Share Posted July 3, 2013 hi guys, just goning to put my 300mm setup on and was wondering where and why do you put copper grease thanksuse it any where the pads rub the caliper take care not to over do it near the pad face ,don't forget to remove and clean/regrease the slides make sure you double check the hoses for rubbing if you are using mk1 mondy ones as mine did and i had to fabricate some brackets Link to comment Share on other sites More sharing options...
