dancool27 Posted August 27, 2013 Share Posted August 27, 2013 Hi i'm looking to have my F4B 1.4 Replaced or Recon'd can anyone recommend a place near to me i live in Folkestone Kent Link to comment Share on other sites More sharing options...
Stu Posted August 27, 2013 Share Posted August 27, 2013 Ashford Motorsport perhaps. Link to comment Share on other sites More sharing options...
dancool27 Posted August 27, 2013 Author Share Posted August 27, 2013 Ashford Motorsport perhaps. Not too keen on their work have had exhausts built and repaired and never seemed that good Anyone know if specialized engines are any good? Specialised Engines Link to comment Share on other sites More sharing options...
scottybo Posted August 28, 2013 Share Posted August 28, 2013 please dont tell me your going to put another 1.4 cvh engine in once its come out Link to comment Share on other sites More sharing options...
Stu Posted August 28, 2013 Share Posted August 28, 2013 Ashford Motorsport perhaps. Not too keen on their work have had exhausts built and repaired and never seemed that good Anyone know if specialized engines are any good? Specialised Engines H would be my choice down that way, he's very capable. Specialised do some strange things sometimes, but they'd probably warranty their work somewhat. Link to comment Share on other sites More sharing options...
dancool27 Posted August 28, 2013 Author Share Posted August 28, 2013 please dont tell me your going to put another 1.4 cvh engine in once its come out Afraid so, she won't let me modify it So got my reply from specialised engines. Best start saving "Dan thank you for your email I have put prices in below for the cost of the rebuild on the engine and fitting prices and if you need any help or advice you will get me on 01375 378606, thank you Ian. Fully reconditioned 1.4 CVH Engine £1095.00 plus vat.Remove old and refit when rebuilt £250.00 plus vat.Oils, oil filter gaskets and antifreeze £89.00 plus vat. Subtotal £1434.00Vat £286.80Total £1720.80. Engine Specs 1.4 CVH standard.With all our engines the cylinder block and the cylinder head are cracked tested, acid bath dipped and hot washed chemically cleaned, all of our engines come with a new oil pump, new main and new big end bearings, reground crankshaft to the first oversize, 4 new oversize pistons as all the blocks are over bored and honed, with new rings and Goodgeon pins, new core plugs, new oil seals and all new gaskets, phosphor bronze valve guide liners, three way valve seat cutting, new valve springs, new cam followers, new rocker nuts, new camshaft, new late type valve stem oil seals (top hat type)." Link to comment Share on other sites More sharing options...
Stu Posted August 28, 2013 Share Posted August 28, 2013 What do you think is wrong with the current engine? Link to comment Share on other sites More sharing options...
dancool27 Posted August 28, 2013 Author Share Posted August 28, 2013 What do you think is wrong with the current engine? I have no clue it pulls fine just has this rattle at 4000rpm Link to comment Share on other sites More sharing options...
scottybo Posted August 28, 2013 Share Posted August 28, 2013 What do you think is wrong with the current engine? I have no clue it pulls fine just has this rattle at 4000rpm its a cvh engine.... ive got a perfectly good 1600 zetec engine u can have here if u want for free. ill throw in everything you need to convert it apart from the wiring loom Link to comment Share on other sites More sharing options...
Stu Posted August 28, 2013 Share Posted August 28, 2013 What do you think is wrong with the current engine? I have no clue it pulls fine just has this rattle at 4000rpm ... and where is the oil level on the dipstick? Link to comment Share on other sites More sharing options...
sidrick Posted August 28, 2013 Share Posted August 28, 2013 Surely you could buy a used engine with warranty and have it fitted about 4 times over for that :\ Link to comment Share on other sites More sharing options...
Craig855S Posted August 28, 2013 Share Posted August 28, 2013 to spend 1800 quid on a 1.4 escort is beyond mental. Either replace the whole car, with a younger escort, move away from escorts altogeher, or buy and fit a zetec engine into your current chassis (if youre wierdly attatched to it) Link to comment Share on other sites More sharing options...
dancool27 Posted August 28, 2013 Author Share Posted August 28, 2013 What do you think is wrong with the current engine? I have no clue it pulls fine just has this rattle at 4000rpm ... and where is the oil level on the dipstick? Lol always a good level she doesn't use any, even had an oil and filter change with decent oil and a motorcraft filter to spend 1800 quid on a 1.4 escort is beyond mental. Either replace the whole car, with a younger escort, move away from escorts altogeher, or buy and fit a zetec engine into your current chassis (if youre wierdly attatched to it) Think it may be a trip to my usual garage first to let him investigate it further. Link to comment Share on other sites More sharing options...
scottybo Posted August 29, 2013 Share Posted August 29, 2013 to spend 1800 quid on a 1.4 escort is beyond mental. Either replace the whole car, with a younger escort, move away from escorts altogeher, or buy and fit a zetec engine into your current chassis (if youre wierdly attatched to it) i did offer a free zetec.enfine Link to comment Share on other sites More sharing options...
