mike_g21 Posted March 17, 2014 Share Posted March 17, 2014 Hey guys, it's been a very very long time since I've posted but I wondered if anyone can shed some light on the mess I've got.I've got a gti that I have just done the head gaskit and cam belt on it. I bought the car with the head gaskit blown and running rough. Its all back together properly but it has a bad misfire and when testing the ht leads cylinder one pulled off makes no change cylinder 2's lead makes it misfire a little more but cylinder 3 is going mental and sparking to anything and everything. I have changed spark plugs ht leads and coil pack and it makes no change. Errrr please help I'm losing the will to live. Any help will be welcomed thanks a lot guys Link to comment Share on other sites More sharing options...
scottybo Posted March 17, 2014 Share Posted March 17, 2014 Maybe its out of time. Checked camshaft sensor? Link to comment Share on other sites More sharing options...
horizon Posted March 18, 2014 Share Posted March 18, 2014 Silicon Grease around the ceramic of the plug will help this - very common problem on the zetec and this is what Ford used to do to prevent this. Link to comment Share on other sites More sharing options...
mike_g21 Posted March 19, 2014 Author Share Posted March 19, 2014 Thanks for the tips guys ill start looking and try these out see if it helps Link to comment Share on other sites More sharing options...
etrebus Posted March 19, 2014 Share Posted March 19, 2014 Thanks for the tips guys ill start looking and try these out see if it helpsworth doing a compression test first Link to comment Share on other sites More sharing options...
mike_g21 Posted March 21, 2014 Author Share Posted March 21, 2014 Compression testing was on my list to do aswell I'm just having problems finding one that can get down to the spark plug holes as its quiet a deep head. Even if it is lacking compression in a cylinder would that cause the bad sparking. Link to comment Share on other sites More sharing options...
