marshy Posted September 11, 2014 Share Posted September 11, 2014 my passenger rear wheel bearing keeps failing.. this is the second ive replaced in a year or less...anyone have any ideas as why or what could be causing this??? Link to comment Share on other sites More sharing options...
shifty Posted September 11, 2014 Share Posted September 11, 2014 Are you replacing the bearing guide at the same time mate? Link to comment Share on other sites More sharing options...
marshy Posted September 11, 2014 Author Share Posted September 11, 2014 tbh i dont know .. i give it to mechchanic and he fits whatever i buy from motorspares so probably not mate... Link to comment Share on other sites More sharing options...
blacksofstichill Posted September 12, 2014 Share Posted September 12, 2014 "Bearing Guide"? I'm not sure what you mean by that but I'm guessing you might mean the stub axle? It might be that the stub axle is worn, you'd have to get the garage to check when they have the bearing off and replace it if need be. Other than that, there's not many reasons why a bearing should fail so often really. 1 Link to comment Share on other sites More sharing options...
demented Posted September 12, 2014 Share Posted September 12, 2014 This occurred to one of my cars too, also rear passenger. I believe it was caused by a buckled/egg shaped alloy wheel fitted to that axle. Link to comment Share on other sites More sharing options...
shifty Posted September 12, 2014 Share Posted September 12, 2014 "Bearing Guide"? I'm not sure what you mean by that but I'm guessing you might mean the stub axle?Sorry I didn't mean the stub axle, I was referring to the rings that press into the brake drum which come with the bearing kit.I can't remember what they're called though! I'd imagine some lazy mechanics don't replace them at the same time as the bearings. 1 Link to comment Share on other sites More sharing options...
blacksofstichill Posted September 12, 2014 Share Posted September 12, 2014 Sorry I didn't mean the stub axle, I was referring to the rings that press into the brake drum which come with the bearing kit.I can't remember what they're called though! I'd imagine some lazy mechanics don't replace them at the same time as the bearings.Ah, I know what you mean now. Those are the outer races of the bearing, they come as part of a bearing kit and are supposed to be fitted but you're right, I've heard of some places just fitting the inner races and running them on the old worn outer races.....not good practice! 1 Link to comment Share on other sites More sharing options...
bongo Posted September 17, 2014 Share Posted September 17, 2014 I had a ovaled/worn stub axle when I had the rs rear disc setup,that's when I changed to the focus setup. Link to comment Share on other sites More sharing options...
