Mk6 Si Ross Posted March 22, 2004 Share Posted March 22, 2004 i just had a question from a buyer would my wheels fit a Toyota Yaris, i thought at 1st they were having a laugh but check this out Corolla, MR2 >90, Paseo, Starlet, Yaris - PCD = 4 x 100, Offset = 35...38, C/Bore = 54.0 Escort, Orion, Focus, Sierra, Mondeo - PCD = 4 x 108, Offset = 35...38, C/Bore = 63.3 So what does all this mean???? the offsets seem the same don't they??? whats the other figures mean, will they or won't they fit this Yaris??? if they do go on how well they sit?? Link to comment Share on other sites More sharing options...
white_van_matt Posted March 22, 2004 Share Posted March 22, 2004 PCD = Pitch circle diameter (circumference of circle drawn between holes for wheel nuts/studs).C/Bore i'd imagine means centre bore - i.e. the size of the hole in the middle. I think you can change this with a spigot ring, but the PCD could be a problem Link to comment Share on other sites More sharing options...
JonC Posted March 22, 2004 Share Posted March 22, 2004 PCD is the distance between the studs. basically the yaris's studs are closer together there is no way of fitting the wheels onto a yaris. Link to comment Share on other sites More sharing options...
sime73 Posted March 22, 2004 Share Posted March 22, 2004 Link to comment Share on other sites More sharing options...
Mk6 Si Ross Posted March 22, 2004 Author Share Posted March 22, 2004 cheers guys Link to comment Share on other sites More sharing options...
Mk6 Si Ross Posted March 26, 2004 Author Share Posted March 26, 2004 another bloke asked if they fitted a Vauxhall but i don't think they do again cos of the above but what about other cars that are 4 X 108 PCD???? Pug and Citroen are on most current models but with much smaller offsets of about 15 to 22, would they fit with spacers n things????? Model / P.C.D. / Offset / C/Bore Saxo (some models) 4 x 108 / 12...18 / 65.0 BX, ZX, Xantia, Xsara, Saxo 4 x 108 / 15...22 / 65.0 and Model / P.C.D. / Offset / C/Bore 106 (4-stud) 4 x 108 / 12...18 / 65.0 205, 306, 309, 405, 406 4 x 108 / 15...22 / 65.0 206, 307 4 x 108 / 25 / 65.0 any help would be appriciated Link to comment Share on other sites More sharing options...
K3V HA Posted March 26, 2004 Share Posted March 26, 2004 Ross, im pretty sure that they wouldnt fit citroen, but i know people with 306's in ford fitment with spacers. Think g spot has em on his pug! Link to comment Share on other sites More sharing options...
Mk6 Si Ross Posted March 26, 2004 Author Share Posted March 26, 2004 most citroens are pug's anyway aren't they?!!!!! 106/Saxo etc ??? see figures above Link to comment Share on other sites More sharing options...
sortedford Posted March 26, 2004 Share Posted March 26, 2004 they will fit pugs with spacers ross i would think theyll fit shitrens too cos most the bits are the same as you said Link to comment Share on other sites More sharing options...
