sortedford Posted September 3, 2004 Share Posted September 3, 2004 ive been having a problem with the car starting, ie u turn the ignition and have to hold it on for about 2 secsbefore it even turns over, but starts first time, no problem then.but its now not starting, just been out for a drive, came in wanted to go back out after 5 minuites, and nothing. it isnt a flat battery. so anyone know anything? Link to comment Share on other sites More sharing options...
Graeme Posted September 3, 2004 Share Posted September 3, 2004 try your other key mate. when i had my fiesta it did the same thing. the key had some how buggered up. Give it a whirl. G Link to comment Share on other sites More sharing options...
Rich Posted September 3, 2004 Share Posted September 3, 2004 could be the fuse box m8y, we have been having shite loads of rain, heavy rain at that so water could have got into your fuse box and be interfearing with your ignition relay, when you turn your key to ACC and ON does your normal electrics come on? Link to comment Share on other sites More sharing options...
sortedford Posted September 3, 2004 Author Share Posted September 3, 2004 everything else works normall, ill try the spare key later (just off to work) its been inside for the past week so shouldnt be water in anything ? Link to comment Share on other sites More sharing options...
JonC Posted September 3, 2004 Share Posted September 3, 2004 dry joint on the ignition relay connection try resoldering it check earths check ignition cable isnt worn away at any point Link to comment Share on other sites More sharing options...
K3V HA Posted September 3, 2004 Share Posted September 3, 2004 Is this in the right section?? Link to comment Share on other sites More sharing options...
Rich Posted September 3, 2004 Share Posted September 3, 2004 everything else works normall, ill try the spare key later (just off to work) its been inside for the past week so shouldnt be water in anything ? its been dry for the past week and i still have water in my car Link to comment Share on other sites More sharing options...
