Graeme Posted May 15, 2005 Share Posted May 15, 2005 HELP HELP HELP!!! Was giving my car a fair bit of shet the other night "raggin it" stopped up for a bit and the car started pissin with oil. not badly. well i topped it up and was fine for a bit was driving it sensible... Well got abotu 10 mins away dipped the clutch to change down gear and the car cuts out Tryed to start it all i hear is one "TICK" and thats it Got it towed home went and checked it yesterday morning the oil leak has stopped (was coming from the oil filter) but the car still wont start!!! It's not the battery as it's fine (got it checked at halfords as it's only 3 days old) the cars had a new alternator a few yrs back (but i would have thought that if the batt is fine the alternator would be fine too as it's charging it...) So leads me to think it's the starter motor... anyone else agree? like i said all i hear when i turn the key the whole way is one "TICK" thats it.... I have power to everything else in the car tho. checked all my fuses/relays too. Help guys!!! Link to comment Share on other sites More sharing options...
j4ffa Posted May 15, 2005 Share Posted May 15, 2005 u could have a doggie starter i had a problem where a small piece of metal went between the kog so it wouldnt turn best bet is take starter off n try while its off the car either way u can rule the starter out hope that helps Link to comment Share on other sites More sharing options...
theresa Posted May 15, 2005 Share Posted May 15, 2005 Could be the starter, try hitting it with a hammer and see if it starts after that. Not a p*ss take by the way. Sometimes the starter sticks and a knock with a hammer helps free it off. Worth a try Link to comment Share on other sites More sharing options...
Trig Posted May 15, 2005 Share Posted May 15, 2005 does it turn over, take a spanner and try and turn the crank (if you still can on the newer ford engines). sounds like starter though, did you try bump/jump/push it down a hill starting it? Link to comment Share on other sites More sharing options...
Graeme Posted May 16, 2005 Author Share Posted May 16, 2005 tryed jump starting it still dont work (the batt is def fine as i took it back to halfords and they tested it!) It ticks once when i turn the key all the way doesn't fire on anyof the plugs either as i took one out Link to comment Share on other sites More sharing options...
geordie_aaron Posted May 16, 2005 Share Posted May 16, 2005 oil coming from the air filter? soudns like what ralph (ex-finesse) had....either way its NOT healthy Link to comment Share on other sites More sharing options...
Graeme Posted May 16, 2005 Author Share Posted May 16, 2005 oil filter mate not the air filter!!!... was leaking but thats sorted now Link to comment Share on other sites More sharing options...
Ex-Finesse Posted May 16, 2005 Share Posted May 16, 2005 Is it possible it's not leaking anymore....... because it's all leaked out?? Link to comment Share on other sites More sharing options...
Graeme Posted May 16, 2005 Author Share Posted May 16, 2005 i've topped it all up and checked the dip stick the oil is fine!!! BACK TO THE PROBLEM OF THE CAR NOT STARTING :P Link to comment Share on other sites More sharing options...
McRic Posted May 16, 2005 Share Posted May 16, 2005 if yer getting a click it deffo sounds like the starter, take the terminals off it n give em a good clean then try again Link to comment Share on other sites More sharing options...
Graeme Posted May 16, 2005 Author Share Posted May 16, 2005 i've taken them off and cleaned them already mate Link to comment Share on other sites More sharing options...
Graeme Posted May 16, 2005 Author Share Posted May 16, 2005 waht if i push it along in neutral then whilst its running along put it in 1st then release the clutch? Link to comment Share on other sites More sharing options...
Trig Posted May 16, 2005 Share Posted May 16, 2005 it wont start. try it in second though, thats the way to push start. use a hill if you can as you need a bit of momentum so that when you release the clutch it doesnt stop the car where it is. Link to comment Share on other sites More sharing options...
Graeme Posted May 16, 2005 Author Share Posted May 16, 2005 wheres the earth point for the starter motor boys and gals? in a mk5b zetec? Link to comment Share on other sites More sharing options...
colin_j Posted May 17, 2005 Share Posted May 17, 2005 I had a similar problem and it was the earthin point that was dodgy.It comes off the gearbox next to the starter motor. Link to comment Share on other sites More sharing options...
