Rhinopower05 Posted June 19, 2005 Share Posted June 19, 2005 How much on average will a garage charge to swap a 1.6 for a 1.8, swap over cambelt kit and water pump, cams and headgasket, and have it all working?? Failing that is there a member on here willing to do it for me? Link to comment Share on other sites More sharing options...
Delvey Posted June 19, 2005 Share Posted June 19, 2005 alot,new head gasket alone is about £500 so add an extra £500p.s when doing the engine swap you dont need a new gasket Link to comment Share on other sites More sharing options...
Timmy C Posted June 19, 2005 Share Posted June 19, 2005 £500 for a head gasket Link to comment Share on other sites More sharing options...
Ex-Finesse Posted June 19, 2005 Share Posted June 19, 2005 (edited) swap over cambelt kit and water pump, cams and headgasket, and have it all working?? I'd heavily recommend a new cambelt, your old one will have been used to tension. Re-fitting and tensioning it could be risky. Also, why cams and headgasket?? Are you only getting a 1.8 bottom end?? Get a complete 1.8 engine. I have one for sale for £100 I'll get a link in a moment EDIT: Link! Edited June 19, 2005 by Ex-Finesse Link to comment Share on other sites More sharing options...
Mk6 Si Ross Posted June 20, 2005 Share Posted June 20, 2005 £500 for a head gasket <{POST_SNAPBACK}> ask M4tt how much he paid from ford for the RS to get a new head gasket!!! Link to comment Share on other sites More sharing options...
Drk_red_Mk5 Posted June 20, 2005 Share Posted June 20, 2005 think sum1s getting mugged off there then? 500? thats pretty mad! Link to comment Share on other sites More sharing options...
Rhinopower05 Posted June 20, 2005 Author Share Posted June 20, 2005 been quoted £150 + vat,. bargain! Link to comment Share on other sites More sharing options...
ploppy Posted June 20, 2005 Share Posted June 20, 2005 do the head gasket urself. did mine, just make sure there is two people to lift the head off so u dont do ur back in. Link to comment Share on other sites More sharing options...
plumber60 Posted June 20, 2005 Share Posted June 20, 2005 been quoted £150 + vat,. bargain!<{POST_SNAPBACK}>didnt know john wayne was still alive Link to comment Share on other sites More sharing options...
Rhinopower05 Posted June 20, 2005 Author Share Posted June 20, 2005 been quoted £150 + vat,. bargain!<{POST_SNAPBACK}>didnt know john wayne was still alive <{POST_SNAPBACK}> Mechanic myself and family have used for the last 15 years, trust him with anything! to do a head gasket (forgetting about cambelt etc) is it literally undo head bolts, put new head gasket in and bolt back together and toqrue up the bolts? Link to comment Share on other sites More sharing options...
RobMk6 Posted June 22, 2005 Share Posted June 22, 2005 no cos u gotta re-time the engine (unless you locked the cams) i can do a swap PM me with requirements and bits u need and bits you have already and i'll give ya a price based on the time it takes, (depending where ur from as im from SW Wales and theres gotta be sum1 closer) Link to comment Share on other sites More sharing options...
Danzetec Posted June 22, 2005 Share Posted June 22, 2005 Mechanic myself and family have used for the last 15 years, trust him with anything! to do a head gasket (forgetting about cambelt etc) is it literally undo head bolts, put new head gasket in and bolt back together and toqrue up the bolts?<{POST_SNAPBACK}> Aluminium heads distort with heat so when its removed you get it skimmed (to do a proper job). Also head bolts should only be torqued twice and then replaced. Link to comment Share on other sites More sharing options...
