celsis Posted June 29, 2005 Share Posted June 29, 2005 Guys, I've got a small problem where my car sorta stops while sitting at lights. Now I know that it's probably the idling valve and I'm gonna get that fixed. there's another wee problem hoever and that's the smell of petrol in the cab when I'm in neutral or first gear. Could this be to do with the idling valve? Cheers! Link to comment Share on other sites More sharing options...
ploppy Posted June 29, 2005 Share Posted June 29, 2005 check ur fuel lines. Link to comment Share on other sites More sharing options...
celsis Posted June 29, 2005 Author Share Posted June 29, 2005 check ur fuel lines.<{POST_SNAPBACK}> looked under the car and nothing seems to be leaking. And it only smells when the car is at low speed. Could it be petrol backing up at the idling valve? Link to comment Share on other sites More sharing options...
geordie_aaron Posted June 29, 2005 Share Posted June 29, 2005 sounds dodgy, i'd get straught to a garage for saftey.... Link to comment Share on other sites More sharing options...
ploppy Posted June 29, 2005 Share Posted June 29, 2005 take a look at the fuel intake pipe on the head when the engine is running. on my zetec, the pressure release valve was a bit funny and petrol pissed out. if ur engine has this make sure u aint got the same. Link to comment Share on other sites More sharing options...
foxdie Posted June 29, 2005 Share Posted June 29, 2005 tis a common smell on turbo cars.... maaaan im gonna miss that smell. Just means its running rich. Reset your ecu. Link to comment Share on other sites More sharing options...
