zero cool Posted February 14, 2003 Share Posted February 14, 2003 eghh forgot to log out my mate.. Link to comment Share on other sites More sharing options...
Redsquirrel Posted February 14, 2003 Share Posted February 14, 2003 Okay my mate put his mk5b seats in my mk6 escort today. They are not completly sealed in yet but anyway.. i noticed today the airbag light is constantly flashing. WHY????? the back seats have nothing to do with it right?? The front seats or steering wheel hasnt been touched. Please help Link to comment Share on other sites More sharing options...
danielk2002uk Posted February 14, 2003 Share Posted February 14, 2003 does it flash a set number of times then stop and repeat again? Cos if it does.... My car the light flashed four times, stopped and did it again. It was something to do with the seatbelts. I'll have a look at the garages invoice cos he wrote on what it meant and post tomorrow Link to comment Share on other sites More sharing options...
Mk6 Si Ross Posted February 14, 2003 Share Posted February 14, 2003 there`s a yellow thing under the Mk6 seats thats the seat belt pre-tensioner, when loose this can cause the light the flash on dash, give it a wiggle, failing that take the bulb out!!! Link to comment Share on other sites More sharing options...
Chrissyboy Posted February 14, 2003 Share Posted February 14, 2003 mine did this for a while but only when the missus drove it and had the seat forward. as soon as I got in and put the seat back it stopped Link to comment Share on other sites More sharing options...
Redsquirrel Posted February 14, 2003 Share Posted February 14, 2003 thanks ill try a few things out and see if it stops. Link to comment Share on other sites More sharing options...
Al Posted February 14, 2003 Share Posted February 14, 2003 Had this on a Mondy i had.Pushed the yellow coupler about, and it stopped, job done.Maybe you put the front seats forward to gain better access to the rear seats?? which tugged at the coupler? Al. Link to comment Share on other sites More sharing options...
Redsquirrel Posted February 14, 2003 Share Posted February 14, 2003 does it flash a set number of times then stop and repeat again? Cos if it does.... My car the light flashed four times, stopped and did it again. It was something to do with the seatbelts. I'll have a look at the garages invoice cos he wrote on what it meant and post tomorrow thanks if you could.. yes it does flash 4 times and off and repeat. The back seat belts were fiddled with but i didnt think the back seats registered with the airbags.. Link to comment Share on other sites More sharing options...
McRic Posted February 15, 2003 Share Posted February 15, 2003 as Al. said check the wires under the front seats might just be coincidence that they have came loose, should be a yellow wire just trace where it goes and make sure its plugged in properly. Link to comment Share on other sites More sharing options...
Pelles Posted February 15, 2003 Share Posted February 15, 2003 Had this on a Mondy i had.Pushed the yellow coupler about, and it stopped, job done.Maybe you put the front seats forward to gain better access to the rear seats?? which tugged at the coupler? Al. ohhh yea i had this problem too, and thought it would be quite funny to take it to ford to get a quote for a laugh.....they wanted in the region of £50 to probably play about with that little wire. A good wiggle and it was sorted by myself Link to comment Share on other sites More sharing options...
