bongo Posted February 23, 2009 Share Posted February 23, 2009 rightguys bit of help needed, my pc flashed up the dreaded blue screen and now refuses to start,so not knowing much i thought it might be hardware problem so i removed ce,rtain things to eliminate,put my old memory back in etc tried another harddrive,still to no avail,my father in law thinks its my motherboard as there's some buldging capacitors on the board,but my main worry is my harddrive,if its knackered have i lost everything on it? but i tried it in my old system which started and it shows my hard drive,but when i click on it it asks me do i want to format it? does this mean its ok. Link to comment Share on other sites More sharing options...
mykez69 Posted February 23, 2009 Share Posted February 23, 2009 tried starting it up into safe mode? Link to comment Share on other sites More sharing options...
bongo Posted February 23, 2009 Author Share Posted February 23, 2009 yep, tried every mode, just get the blue screen Link to comment Share on other sites More sharing options...
mrmetallica Posted February 23, 2009 Share Posted February 23, 2009 yep, tried every mode, just get the blue screen could be hard ware problem try taking everthing out you dont need then boot up see what happens Link to comment Share on other sites More sharing options...
SteveB Posted February 23, 2009 Share Posted February 23, 2009 yep, tried every mode, just get the blue screen could be hard ware problem try taking everthing out you dont need then boot up see what happens Make a note of the long numbers on the blue screen of death and look them up on msdn - tells you what wrong - well sort of Link to comment Share on other sites More sharing options...
mykez69 Posted February 23, 2009 Share Posted February 23, 2009 on the blue screen will say something like hkey_local_memory or something similiar, might not be memory, could be anything, but that line usually indicates whats wrong search the line content on google, Link to comment Share on other sites More sharing options...
DewaltKid Posted February 23, 2009 Share Posted February 23, 2009 All i can recommend is the process of elimination, starting up with the bare minimum of hardware one stick of ram, hd and cd drive. and try and find the faulty problem if the blue screen info doesnt hlp you out Link to comment Share on other sites More sharing options...
bongo Posted February 23, 2009 Author Share Posted February 23, 2009 ok,cheers guys i will try all of the above. Link to comment Share on other sites More sharing options...
bluliz Posted February 23, 2009 Share Posted February 23, 2009 Just try reinstalling windows on another HD, If it goes on Ok and runs...then its was just a windows problem. if it bsod's too then hardware. The bulging Caps dont sound good. but then some PC's can run for years with them like it. Link to comment Share on other sites More sharing options...
SteveB Posted February 25, 2009 Share Posted February 25, 2009 Make a note of the long numbers on the blue screen of death and look them up on msdn - tells you what wrong - well sort of Here's the link to msdn with all the error numbers for windows explained. http://msdn.microsoft.com/en-us/library/cc...6(PROT.10).aspx The pages are difficult to navigate, so download the pdf and search that. There is a link to the pdf at the top of the page: Click here to view this version of the [MS-ERREF] PDF. Link to comment Share on other sites More sharing options...
bongo Posted February 27, 2009 Author Share Posted February 27, 2009 right fellas my code 0x9000009c relates to DEVICE DATA ERROR or bad blocks on my hard drive.they say to solve this i must use autochk,but am i right in thinking you need the windows disk for this? if so i cant find it,i have genuine windows,is there anyway round this? thanks Link to comment Share on other sites More sharing options...
bongo Posted February 28, 2009 Author Share Posted February 28, 2009 all sorted now! hard drive problem, downloaded xp, booted up from disc, ran chkdsk /r fixed problem, very happy indeed Link to comment Share on other sites More sharing options...
