geordie_aaron Posted April 15, 2009 Share Posted April 15, 2009 Ok i've got the laptop (non HD) linked to the TV by the AV port via VGA cable - only problem i've got is i can't get the sound to the TV.... i've tried the headphone 3.5mmjack to component in (on the same channel as VGA) and the sound cuts out on laptop but doesn't come out tv.... so fail. any ideas?Cheers Link to comment Share on other sites More sharing options...
duffa Posted April 15, 2009 Share Posted April 15, 2009 (edited) i take it this is the back of your TV http://www.hdtvtest.co.uk/image/hdtv/Samsung-LE40A656/rear-connections.jpg are there not any settings for sound on the tv for the pc channel ? Edited April 15, 2009 by duffa Link to comment Share on other sites More sharing options...
dutchkev Posted April 15, 2009 Share Posted April 15, 2009 with my TV i have to assign the rear audio to the component channel before any sound is emited if that makes any sence? Link to comment Share on other sites More sharing options...
Ramesh Posted April 15, 2009 Share Posted April 15, 2009 do u mean component or composite? I do the same thing with composite sound and use the d-sub from the computer to output the vga signal. You might have to tell the tv through the menu where it is getting the sound from. Link to comment Share on other sites More sharing options...
geordie_aaron Posted April 15, 2009 Author Share Posted April 15, 2009 very similar duffa - although my 3rd HDMI is on the side........i dont have to use digital input do i? (FFS) as for assigning where sound comes from - no options i've seen, closest i've come to is 'sound select: main' but have no means of changing as its greyed out in every source/channel Link to comment Share on other sites More sharing options...
duffa Posted April 15, 2009 Share Posted April 15, 2009 i would have said use the pc in audio with the 3.5mm jack ... but your already doing that ... have you tried putting the audio out from your laptop to another source .. pc speakers or something just top make sure your headphone output is working Link to comment Share on other sites More sharing options...
SteveB Posted April 16, 2009 Share Posted April 16, 2009 i would have said use the pc in audio with the 3.5mm jack +1. You might find that you have a seperate pc in volume level on the tv - check out the menus Link to comment Share on other sites More sharing options...
geordie_aaron Posted April 16, 2009 Author Share Posted April 16, 2009 just goin to burn to DVD fcuk it. can't be arsed buying more wires cheers all lol Link to comment Share on other sites More sharing options...
