onehotminute_191 Posted May 13, 2009 Share Posted May 13, 2009 im thinking of getting an external hard drive or media drive to store all my photos, videos and music. (running out of space on the laptop) the benefit of a media drive being that it'll plug straight into the tv and can be capable of HD video via HDMI. the benfit of an external hard drive being cheaper for the size and easily upgradeable and can use more than one drive. but will the external hard drive plug into the PS3 and be able to play the video from it? Link to comment Share on other sites More sharing options...
vinnyvangough Posted May 14, 2009 Share Posted May 14, 2009 As far as i am aware it will. Not tried it myself but am sure it will as its only another external source, such as a mobile or something Link to comment Share on other sites More sharing options...
onehotminute_191 Posted May 17, 2009 Author Share Posted May 17, 2009 (edited) only one reply lol. cheers mate. i heard that it'll read it as long as its formatted FAT32. not NTFS. can give it a try i suppose. Edited May 17, 2009 by onehotminute_191 Link to comment Share on other sites More sharing options...
Andy 3i Posted May 18, 2009 Share Posted May 18, 2009 mine doesnt read my usb hard drive, yet it'll read my phone card Link to comment Share on other sites More sharing options...
Lee_2f2f Posted May 18, 2009 Share Posted May 18, 2009 (edited) if its an external hard drive that reads as a mass storage device, or external hard drive, then it should be ok.... but this is my example: Integral usb 2.0 External Hard drive caddy (for internal HDD's) wont read on PS3 because it has self install drivers, so the PS3 does not recognise it. Kingsington USB 2.0 Datatraveler Mem stick - again, this reads because it comes up as "mass storage" where as if it shown up with all strange details then it wont read. Nokia N95 8gb - reads as Mass Storage device, so that works no problem as well. Hope this helps. i heard that it'll read it as long as its formatted FAT32. not NTFS. can give it a try i suppose. Dont see that making any difference, my Datatraveler is Fat format, and my mates WD 1TB HDD was NTFS and it still read ok... Edited May 18, 2009 by Escort_2f2f Link to comment Share on other sites More sharing options...
wwwd Posted June 7, 2009 Share Posted June 7, 2009 I have a 500GB external hard drive which stores all my videos, music and photographs and it works perfectly fine with my PS3. Plug it into a free USB slot, switch it on and you can run all the videos, music and photographs through your PS3 Link to comment Share on other sites More sharing options...
onehotminute_191 Posted June 8, 2009 Author Share Posted June 8, 2009 mine dont work with my usb stick or my passport drive. not sure of the usb stick but the drive is NTFS. might try formatting the usb in FAT32 and seeing what happens Link to comment Share on other sites More sharing options...
Lee_2f2f Posted June 9, 2009 Share Posted June 9, 2009 mine dont work with my usb stick or my passport drive. not sure of the usb stick but the drive is NTFS. might try formatting the usb in FAT32 and seeing what happens You can try it fella, but I'm sure it doesnt matter??? as I posted above, my PS3 has read both before.. I'm sure of it. Link to comment Share on other sites More sharing options...
wwwd Posted July 13, 2009 Share Posted July 13, 2009 It will only work if the USB Hard Drive has an external power source. You cannot power a USB Hard Drive using the power from the PS3. That only works on PC's. Link to comment Share on other sites More sharing options...
onehotminute_191 Posted July 14, 2009 Author Share Posted July 14, 2009 It will only work if the USB Hard Drive has an external power source. You cannot power a USB Hard Drive using the power from the PS3. That only works on PC's. is that because the power supply is insufficient? because i have a usb lead with 2 usb a plugs, so it doubles the available power. might try that out Link to comment Share on other sites More sharing options...
wwwd Posted August 19, 2009 Share Posted August 19, 2009 It will only work if the USB Hard Drive has an external power source. You cannot power a USB Hard Drive using the power from the PS3. That only works on PC's. is that because the power supply is insufficient? because i have a usb lead with 2 usb a plugs, so it doubles the available power. might try that outWell probably, but the bottom line it doesn't work. Get a USB drive with an external power source and you're on the road to a dreamworld. Link to comment Share on other sites More sharing options...
