Danny1107 Posted December 22, 2009 Share Posted December 22, 2009 installed windows7 the other day, and ever since my speakers have been crackling alot, the speakers arent at fault, I tried another set, tried different audio outputs, tried headphones, still crackling anyone else had this problem? any ideas how to fix it? Link to comment Share on other sites More sharing options...
sidrick Posted December 22, 2009 Share Posted December 22, 2009 Audio driver, find one on the manufacturers website. Link to comment Share on other sites More sharing options...
MCCORNY11 Posted December 22, 2009 Share Posted December 22, 2009 does it use any programs for audio? my computer used an application for controlling inputs and outputs for diff ports! you can either reinstall application and/or drivers and if this still doesn't work then there should be a windows update for it shortly or one from the manufacture Link to comment Share on other sites More sharing options...
Lee_2f2f Posted December 22, 2009 Share Posted December 22, 2009 Is the Soundcard Integrated or is it on a seperate Chip? Is it compatible with Windows 7? did you check first? What sound card is it, I will have a google around for some 7 Drivers. Link to comment Share on other sites More sharing options...
Danny1107 Posted December 22, 2009 Author Share Posted December 22, 2009 Is the Soundcard Integrated or is it on a seperate Chip? Is it compatible with Windows 7? did you check first? What sound card is it, I will have a google around for some 7 Drivers. its on the motherboard, will try downloading audio driver like sid said hopefuly that will work had a search on the acer website and the audio driver is for xp and vista but not windows7 Link to comment Share on other sites More sharing options...
Lee_2f2f Posted December 22, 2009 Share Posted December 22, 2009 IIRC Windows 7 has been built on some of XP's sources? Try the XP driver see if thats any good, then try the Vista driver, try installing in compatability mode see if you get anywhere.... That is as much as I can say.. Stu & Sid know more than me. Link to comment Share on other sites More sharing options...
Danny1107 Posted December 22, 2009 Author Share Posted December 22, 2009 IIRC Windows 7 has been built on some of XP's sources? Try the XP driver see if thats any good, then try the Vista driver, try installing in compatability mode see if you get anywhere.... That is as much as I can say.. Stu & Sid know more than me. going to try both drivers, hopefuly that will work failed to install the drivers will try find windows7 drivers for one of the sound cards i've got laying about Link to comment Share on other sites More sharing options...
duffa Posted December 22, 2009 Share Posted December 22, 2009 had this problem when i set up a friends new tower..sound was fine then went off , same thing ..crackling , after a search on google found a solution , you have to uninstall the drivers for sound then reinstall them Link to comment Share on other sites More sharing options...
Danny1107 Posted December 22, 2009 Author Share Posted December 22, 2009 still not working with the onboard sound, will install a sound card later Link to comment Share on other sites More sharing options...
PeeWee Posted December 22, 2009 Share Posted December 22, 2009 Fully uninstall your sound card then use the Vista drivers. It should be fine, although you havnt said what the soundcard is except onboard & Acer? Link to comment Share on other sites More sharing options...
Danny1107 Posted December 22, 2009 Author Share Posted December 22, 2009 model of the computer is acer aspire m1610 lb7z motherboard model is f672cr only just got back on, cocked it up when i was changing bios settings overclocking it, all's good now, overclocked to 2.4ghz, the most it will let me do with the bios settings I can change (standard was 1.8ghz) going to try get the sound working properly now, it does work, just crackles and its really annoying tbh if I cant get the onboard sound to work properly then I'll try a creative sound card I've got (model: SB0220) I did a quick search and people have got them working on windows7 Link to comment Share on other sites More sharing options...
