duffa Posted March 12, 2010 Share Posted March 12, 2010 after stupedly getting a trojan , and setting pc to start up in safe mode , i couldnt close pc down or start in safe mode , so deceided to do a fresh install of windows , put the disc in , but everytime it tries to set up a new version of xp comes up with 'windows xp setup cannot run under safemode, set up will restart now'...but obviously with me changing the pc to start up in safemode it wont let me put new install , i can get into the CMOS setup utility..but cant work out how to stop pc starting in safemode ... HELP !!!!!! Link to comment Share on other sites More sharing options...
MCCORNY11 Posted March 12, 2010 Share Posted March 12, 2010 (edited) if its got a floppy drive download a boot disk (windows 98 works well for me) format the drive and start again Edited March 12, 2010 by MCCORNY11 Link to comment Share on other sites More sharing options...
duffa Posted March 12, 2010 Author Share Posted March 12, 2010 no floppy disc ... its stuck in a loop...gets so far then comes up with same message windows xp cannot run under safe mode Link to comment Share on other sites More sharing options...
PeeWee Posted March 12, 2010 Share Posted March 12, 2010 (edited) In the bios change the boot up sequence to boot from cd, pop your xp disc in & follow your on screen instructions, install xp fresh including formatting the hard drive.Im assuming you have you stuff backed up as this will wipe the lot. Choose the bottom option here. Fresh copy.http://web.mit.edu/ist/products/winxp/advanced/repair03.gif Ill add another screen that might help. Delete the partition, see bottom option.http://www.theeldergeek.com/images/XP%20Home%20Setup%20Graphic/FF.gif Edited March 12, 2010 by PeeWee Link to comment Share on other sites More sharing options...
duffa Posted March 12, 2010 Author Share Posted March 12, 2010 In the bios change the boot up sequence to boot from cd, pop your xp disc in & follow your on screen instructions, install xp fresh including formatting the hard drive.Im assuming you have you stuff backed up as this will wipe the lot. i tried to change the boot up from disc , but that didnt work , i've done something ..not sure what and it seems to be installing now , i got most of my stuff saved somewhere , but i'm raiding the wifes purse..told her ages ago i needed an external HD to back everything up , and i really must sort myself a recovery disc out !! Link to comment Share on other sites More sharing options...
wwwd Posted March 18, 2010 Share Posted March 18, 2010 I was going to suggest what Pete said. Start your computer in DOS and run the installation CD that way. There shouldn't be anything to prevent you doing that successfully. I've done that as a last resort for the last 15 years and its always worked. Link to comment Share on other sites More sharing options...
