tomsy Posted December 4, 2011 Share Posted December 4, 2011 Hi all two very simple questions i need answering when removing front bumper on a gti do you have to disconnect any part of the radiator, only asking because it mentions this in haynes manual after a quick look i dont see why you would need to. Second question not related to first do you need to remove wheel arch liner to change side indicators thanks for your help Tomsy. Link to comment Share on other sites More sharing options...
JC Posted December 4, 2011 Share Posted December 4, 2011 to remove bumper, dont touch rad, 2 screws either side that go through bumper into atch lining, them 4 nuts at the front. side repeaters slide parallel to side of car and the pull out Link to comment Share on other sites More sharing options...
SLEEMAN Posted December 4, 2011 Share Posted December 4, 2011 Both questions no!! You need to use ratchet spanners to remove the nuts for the bumper Link to comment Share on other sites More sharing options...
Naylor2006 Posted December 5, 2011 Share Posted December 5, 2011 Both questions no!! You need to use ratchet spanners to remove the nuts for the bumper Unless you like loosing skin working it off for 2 hours with a spanner, got that was an awful night, then put it back on with same spanner! Never again Link to comment Share on other sites More sharing options...
Slik Johnson Posted December 5, 2011 Share Posted December 5, 2011 I think ratched spanners are the way forward Link to comment Share on other sites More sharing options...
