sevenhills Posted July 6, 2012 Share Posted July 6, 2012 HeeyyYesterday i decided to put down my drivers side window as it was a nice day for a change, anyway when i came to put it back up there was no luck the passenger side window still worked but there is nothing happing with the drivers side i fiddled around with the switch etc took it all apart changed the two window switches and the boot release but still no luck. I also took my door panel off to try and push the window back up but then i realised its obviously still stuck in the motor. is there anything i can do to get the window up until i fix it? does anyone know what the problem might be? cheers Link to comment Share on other sites More sharing options...
stoo2000 Posted July 6, 2012 Share Posted July 6, 2012 Did you try wiggling the wires that go into the bottom of the switch ? Just a thought, if one may be loose for whatever reason. Link to comment Share on other sites More sharing options...
shawdreamer Posted July 6, 2012 Share Posted July 6, 2012 could be any number of unseen causes but generally Ive found when you get your specific issue its invariably mechanical related and not electrical as when the the electrics go they usually go completely whether its the motor or switch, fords door looms in general are very simple things so there's very little to go tits up on them. chances are you have as I mentioned a mech issue with the motor, that could range from a burnt out winder motor to a interior tangled cable (seen that twice and both times it ultimately snapped the cable trying to mend it), without being able to get hands on Id have to lean in the direction of motor and runner replacement (not as hard as it first seems, just requires some rivet drilling replacing) For the time being you can detach the glass mount from the winder runner and lift the glass back up into place where it can be wedged/propped in place till you can get round to sorting the issue (glass is attached to the runner by two gold coloured torque screws that can be accessed through the door panels metal skin via either of four holes depending on whether the windows fully down or up) Link to comment Share on other sites More sharing options...
Hezz Posted July 6, 2012 Share Posted July 6, 2012 you'll prob find its the wiring to the plug in the switch rather than the switch itself - if you look at the female prongs they'll be burnt away Link to comment Share on other sites More sharing options...
shawdreamer Posted July 6, 2012 Share Posted July 6, 2012 if you look at the female prongs they'll be burnt away My missus said she'd never use hot wax strips again after she did that herself. Link to comment Share on other sites More sharing options...
MCCORNY11 Posted July 6, 2012 Share Posted July 6, 2012 something to quickly try as mine went and it was the swtich, try pluging the loom from drivers side into passenger side of the switch and then test Link to comment Share on other sites More sharing options...
