scottybo Posted March 7, 2013 Share Posted March 7, 2013 can someone write me up a guide.for fitting focus rear discs.to the mk6 escort thanks muchly Link to comment Share on other sites More sharing options...
demented Posted March 8, 2013 Share Posted March 8, 2013 http://www.escortevolution.co.uk/forums/in...grade&st=15 Link to comment Share on other sites More sharing options...
dalelc16 Posted March 16, 2013 Share Posted March 16, 2013 Hi i did the converstion last week on my car if you need help.just ask Link to comment Share on other sites More sharing options...
scottybo Posted March 17, 2013 Author Share Posted March 17, 2013 Hi i did the converstion last week on my car if you need help.just ask was it difficult to do? what were the biggest problems you came across Link to comment Share on other sites More sharing options...
dalelc16 Posted March 17, 2013 Share Posted March 17, 2013 the biggest prob i had ,was getting the parts. the link up above is good to use.your drums has a abs ringwhich you need to fit to stub axle on the st170 but you will find that on the st170 the abs ring is diffrent size you need to take that off and get the bit it pushes on to machined smaller to fit the escort one but when fitting on to car make sure it isnt to close or to far away from the senser as your abs light will come on.also you need to drill the hole bigger to fit the abs senser but when i took my drums off and undo the bolt which holds it i couldnt get the senser out of hole so had to cut wire and buy another abs loom off ebay. it is easy to do and anyone can do it but you need to mod for abs ring to fit,thats the only pain and the ass part.it looks good and works finealso buy a new hand brake cable dont use second hand Hi i did the converstion last week on my car if you need help.just ask was it difficult to do? what were the biggest problems you came across everything just bolts on except- Link to comment Share on other sites More sharing options...
scottybo Posted March 17, 2013 Author Share Posted March 17, 2013 the biggest prob i had ,was getting the parts. the link up above is good to use.your drums has a abs ringwhich you need to fit to stub axle on the st170 but you will find that on the st170 the abs ring is diffrent size you need to take that off and get the bit it pushes on to machined smaller to fit the escort one but when fitting on to car make sure it isnt to close or to far away from the senser as your abs light will come on.also you need to drill the hole bigger to fit the abs senser but when i took my drums off and undo the bolt which holds it i couldnt get the senser out of hole so had to cut wire and buy another abs loom off ebay. it is easy to do and anyone can do it but you need to mod for abs ring to fit,thats the only pain and the ass part.it looks good and works finealso buy a new hand brake cable dont use second hand Hi i did the converstion last week on my car if you need help.just ask was it difficult to do? what were the biggest problems you came across everything just bolts on except- abs.....LOL! Link to comment Share on other sites More sharing options...
dalelc16 Posted March 17, 2013 Share Posted March 17, 2013 the biggest prob i had ,was getting the parts. the link up above is good to use.your drums has a abs ringwhich you need to fit to stub axle on the st170 but you will find that on the st170 the abs ring is diffrent size you need to take that off and get the bit it pushes on to machined smaller to fit the escort one but when fitting on to car make sure it isnt to close or to far away from the senser as your abs light will come on.also you need to drill the hole bigger to fit the abs senser but when i took my drums off and undo the bolt which holds it i couldnt get the senser out of hole so had to cut wire and buy another abs loom off ebay. it is easy to do and anyone can do it but you need to mod for abs ring to fit,thats the only pain and the ass part.it looks good and works finealso buy a new hand brake cable dont use second hand Hi i did the converstion last week on my car if you need help.just ask was it difficult to do? what were the biggest problems you came across everything just bolts on except- abs.....LOL! have you got abs brakes. or better still what car you got Link to comment Share on other sites More sharing options...
scottybo Posted March 17, 2013 Author Share Posted March 17, 2013 its a mk6 finnesse x reg and no it doesnt have abs Link to comment Share on other sites More sharing options...
dalelc16 Posted March 17, 2013 Share Posted March 17, 2013 its a mk6 finnesse x reg and no it doesnt have abs most mk6 does have abs but if it doesnt then its realy easy to fit just bolts on use the guid i think you might have abs tho do you have the abs light which comes up when you start the car.or open bonnet and look to the left to if you have a box with dark green pipes coming out of it. Link to comment Share on other sites More sharing options...
scottybo Posted March 17, 2013 Author Share Posted March 17, 2013 its a mk6 finnesse x reg and no it doesnt have abs most mk6 does have abs but if it doesnt then its realy easy to fit just bolts on use the guid i think you might have abs tho do you have the abs light which comes up when you start the car.or open bonnet and look to the left to if you have a box with dark green pipes coming out of it. trust me, i dont have abs, i made the whels lock on more than 1 occasion Link to comment Share on other sites More sharing options...
dalelc16 Posted March 17, 2013 Share Posted March 17, 2013 its a mk6 finnesse x reg and no it doesnt have abs most mk6 does have abs but if it doesnt then its realy easy to fit just bolts on use the guid i think you might have abs tho do you have the abs light which comes up when you start the car.or open bonnet and look to the left to if you have a box with dark green pipes coming out of it. trust me, i dont have abs, i made the whels lock on more than 1 occasion then its easy just buy the setup and bolt on its real easy but you might find when you brake the backend will lock up before your frontso might be worth doing the mondeo and st170 front converstion to, i did this today and realy makes a differnce Link to comment Share on other sites More sharing options...
scottybo Posted March 17, 2013 Author Share Posted March 17, 2013 its a mk6 finnesse x reg and no it doesnt have abs most mk6 does have abs but if it doesnt then its realy easy to fit just bolts on use the guid i think you might have abs tho do you have the abs light which comes up when you start the car.or open bonnet and look to the left to if you have a box with dark green pipes coming out of it. trust me, i dont have abs, i made the whels lock on more than 1 occasion then its easy just buy the setup and bolt on its real easy but you might find when you brake the backend will lock up before your frontso might be worth doing the mondeo and st170 front converstion to, i did this today and realy makes a differnce ive already got the 300s up front hence why im looking to do the rears now as the car looks silly with big fronts and tiny drums lol Link to comment Share on other sites More sharing options...
RO55 Posted March 18, 2013 Share Posted March 18, 2013 Look for Focus 2.0 rear discs as they are £20 a side from a scrappy .. Slightly smaller but allot cheaper. Need to machine the hub down for the Escort collector ring and drill the hub out for the pick up .. ST170 hand brake cable .. Puma 1.7 16v Brake lines .. Link to comment Share on other sites More sharing options...
RO55 Posted March 18, 2013 Share Posted March 18, 2013 EDIT: Might as well throw some pics up seen as though my PB is open .. I did a guide and posted it on RS2000 forum and they moved it to a Memebers only section lol .. £20 a side: http://i127.photobucket.com/albums/p124/rosspec/Focus%20ABS/SSL23101gun.jpg All the parts: http://i127.photobucket.com/albums/p124/rosspec/Focus%20ABS/SSL23179.jpg Hub machined: http://i127.photobucket.com/albums/p124/rosspec/Focus%20ABS/SSL23107.jpg http://i127.photobucket.com/albums/p124/rosspec/Focus%20ABS/SSL23110.jpg Stub: 15mm drill required. http://i127.photobucket.com/albums/p124/rosspec/Focus%20ABS/SSL23128.jpg http://i127.photobucket.com/albums/p124/rosspec/Focus%20ABS/SSL23121.jpg Assembly: http://i127.photobucket.com/albums/p124/rosspec/Focus%20ABS/SSL23197-1.jpg http://i127.photobucket.com/albums/p124/rosspec/Focus%20ABS/SSL23240.jpg Take it easy! Link to comment Share on other sites More sharing options...
dalelc16 Posted March 18, 2013 Share Posted March 18, 2013 thats a good guid r055 but i think its worth getting the st170 as if you got the front ,you might as well have the back to match. i paid 100 for second hand parts then bought new discs and pads and hand brake cable which was about another 150.which made it quite dear in the endto get machiend was 20 a side. Link to comment Share on other sites More sharing options...
