bhp soothes me Posted July 25, 2013 Share Posted July 25, 2013 Hi, my door seems to be hanging low and then the latch pulls the door up a bit when you shut it and it sits fine. Is there any easy adjustment to slightly raise the door so its inline without the latch bringing it up. Thanks Link to comment Share on other sites More sharing options...
lee grout Posted July 25, 2013 Share Posted July 25, 2013 With all my diy on the car at the mo the doors have been on and off like a yoyo! Mine sit where they sit! I dont even know if they can be adjusted?? not had any problems myself, but I havnt seen.....or 'noticed' should I say any way of adjusting the height. Are the welds for the brackets ok on both the car and the door? Other than that its only 2 pins that hold 1 to the other! Link to comment Share on other sites More sharing options...
dalelc16 Posted July 25, 2013 Share Posted July 25, 2013 Try lifting the door up abit to see if you has some play in it. On my old escort i lifted the door from the bottem and bent it up a little bit. Link to comment Share on other sites More sharing options...
shawdreamer Posted July 25, 2013 Share Posted July 25, 2013 have you tried maybe using a sturdy tree branch just high enough so your feet wont touch the ground?.... "door hanging" seems to problematic if you ask me, what happens if someone opens it?? <reads a bit closer> oh...... right........ sorry Link to comment Share on other sites More sharing options...
