mrrecovery Posted September 21, 2013 Share Posted September 21, 2013 hi guys, few months ago i bought a non running escort gti turbo you might remember from a few years back. Brief is got it running and legal again and now rebuilding it up to a better faster spec. now rear discs, i can only seem to find mk5 rs2k rear beams that have no abs sensors so what can i use instead as i want to keep my abs, whats needed etc.. im going to need stronger lower arms as im looking at 300+ bhp with the new spec and dont think the standard items will last long so what are the options here? i do plan on using it for trackdays so would coilovers be a good recommendation? it currently has konis on her. escort cossie rims on a mk6, do they ruin the ride as much as on the mk5? cheers in advance people Link to comment Share on other sites More sharing options...
scottybo Posted September 21, 2013 Share Posted September 21, 2013 use st170 rear discs. u can modify them so abs still works if you still want it Link to comment Share on other sites More sharing options...
bongo Posted September 21, 2013 Share Posted September 21, 2013 You can get the focus hubs machined to fit the abs ring. Cossie rims although look good,apparently they re awful for the ride and mess up the handling. A few people use royal mail van arms,a few use compbrake adjustable some use polybushed. Not sure on suspension but i think the konis would be better than coilovers,with a decent spring. Link to comment Share on other sites More sharing options...
dalelc16 Posted September 22, 2013 Share Posted September 22, 2013 I have both st170 rear discs and cossy wheels.I do have 205 tyre's aswel and lowered they did rub abit put you can sort that by grinding the lip in the arches. they will not rub if you put 195 on also I did have 215 40 17 alloys on before and the handling hasnt changed you do get a better feel of the road with cossys on. Link to comment Share on other sites More sharing options...
mrrecovery Posted September 22, 2013 Author Share Posted September 22, 2013 thanks for the info guys, i take it i have to lose the abs completely if i dont machine the hubs to accept the abs, surely the focus has abs so cant the original systems be utilised somehow? Link to comment Share on other sites More sharing options...
dalelc16 Posted September 22, 2013 Share Posted September 22, 2013 thanks for the info guys, i take it i have to lose the abs completely if i dont machine the hubs to accept the abs, surely the focus has abs so cant the original systems be utilised somehow? Hi if you do have abs and want a st170 converstion done, then yes it needs to be machined to fit.i can explain how to do this if you like. there is no other way around this. Link to comment Share on other sites More sharing options...
demented Posted September 23, 2013 Share Posted September 23, 2013 Focus ABS system has a different pick up.So the Focus magnetic ABS rings on the hub must be swapped with the toothed ABS ring from the Escort. If the car is fitted as standard with a 4 wheel ABS system, it must be operating as I intended to pass current MOT test, otherwise completely removed. All and more explained here, but will have to join the forum to view it. http://rs2000-16v.com/forum/showthread.php...RS2000-ABS-Ring Link to comment Share on other sites More sharing options...
scottybo Posted September 23, 2013 Share Posted September 23, 2013 i have never had a car with abs so it doesnt worry me about losibg it lol Link to comment Share on other sites More sharing options...
demented Posted September 24, 2013 Share Posted September 24, 2013 To lose ABS, current MOT test rules state entire system must be totally removed otherwise ABS must operate has originally intended. ABS can't be disabled. It's probably easier, to either fit rear discs to a Escort that never had ABS or fit Focus rear discs with ABS rather than remove the entire ABS. Link to comment Share on other sites More sharing options...
mrrecovery Posted September 24, 2013 Author Share Posted September 24, 2013 something to be done over the winter then i think. wrong section but focus rs 18's how well do they fit? and will they ruin the drive? i currently have mondeo 16's but want something else but no idea what to go with that wont look pants, im kind of trying to keep a OEM look but will need 17's as i intend to use focus rs brakes on the front. any suggestions? Link to comment Share on other sites More sharing options...
