hux19 Posted November 15, 2013 Share Posted November 15, 2013 Hi all, Can anybody tell me or have a guide on how to program a new key for a MK6 escort 1.8? I have 3 keys with the car one with a touch, one plain black and red master key. I need to replace the key with the touch as it wont open or lock the car because it badly worn. Thanks Link to comment Share on other sites More sharing options...
scottybo Posted November 15, 2013 Share Posted November 15, 2013 whats 'with a touch' i assume thats remote locking is it? or maybe with a torch? Link to comment Share on other sites More sharing options...
shawdreamer Posted November 15, 2013 Share Posted November 15, 2013 step 1. you'll need your red master key and a minimum of one additional uncoded ford standard key cut to fit your ignition barrel. step 2. Open vehicle via drivers door step 3. upon entering vehicle, insert red "master key" into ignition barrel and turn to "Acc" position on barrel, if successful the imobilizer led indicator should give the appropriate flash step 4. turn the red "master key" to its full extent in the ignition barrel until vehicle engine actually starts. step 5. .... do up your seat belt put the car in gear and drive to the local ford garage and let them do it. Link to comment Share on other sites More sharing options...
demented Posted November 15, 2013 Share Posted November 15, 2013 This post from another forum explains the procedure for a Ford Scorpio, I assumes it'll be same proceedure for any other Ford with PATS. Somewhere in the thread it's states the programming info is in the cars user manual, maybe worth a look if you have one. http://m.passionford.com/forum/showthread....0&styleid=5 Link to comment Share on other sites More sharing options...
