nathanbromley Posted January 13, 2014 Share Posted January 13, 2014 I want to get all these bits together so I can fit them to my car ive also heard it helps to have this to convert to remote central locking which seems way out of my league I am a begging and really aint got a clue. thanks in advance Link to comment Share on other sites More sharing options...
scottybo Posted January 13, 2014 Share Posted January 13, 2014 pm redmex, he recently carried out this conversion on his mexicohttp://www.escortevolution.co.uk/forums/in...p;#entry1527016 Link to comment Share on other sites More sharing options...
escortedal Posted January 15, 2014 Share Posted January 15, 2014 mk2 mondeo ghia with electric sunroof uses the same motor and switch as the escort.simply undo the three torx bolts holding the motor in mondeo, remove motor and wire from motor to switch also. shroud on mondeo is no use in escort so don't buy one.remove your handle and shroud from escort,bolt in new motor .wires for electric sunroof may be tucked down the drivers footwell, they were in my p reg ghia escort.go to ford garage and order a new shroud for electric sunroof at a cost of around£ 17.fit switch into shround and screw it in.simple really.motor you need from mondeo with switch and wire to switch.http://i623.photobucket.com/albums/tt320/escortedal/Copy2ofspares002.jpg wire for sunroof motor may be here.http://i623.photobucket.com/albums/tt320/escortedal/spainparts016.jpg what plug for motor supply looks like. http://i623.photobucket.com/albums/tt320/escortedal/spainparts.jpg shroud fitted in my old escort, screws to remove it are under flaps where visors clip in.http://i623.photobucket.com/albums/tt320/escortedal/spainparts018.jpgsimply feed wire up a piller if its fitted as standard mate, hope this help you. Link to comment Share on other sites More sharing options...
nathanbromley Posted January 18, 2014 Author Share Posted January 18, 2014 mk2 mondeo ghia with electric sunroof uses the same motor and switch as the escort.simply undo the three torx bolts holding the motor in mondeo, remove motor and wire from motor to switch also. shroud on mondeo is no use in escort so don't buy one.remove your handle and shroud from escort,bolt in new motor .wires for electric sunroof may be tucked down the drivers footwell, they were in my p reg ghia escort.go to ford garage and order a new shroud for electric sunroof at a cost of around£ 17.fit switch into shround and screw it in.simple really.motor you need from mondeo with switch and wire to switch.http://i623.photobucket.com/albums/tt320/escortedal/Copy2ofspares002.jpg wire for sunroof motor may be here.http://i623.photobucket.com/albums/tt320/escortedal/spainparts016.jpg what plug for motor supply looks like. http://i623.photobucket.com/albums/tt320/escortedal/spainparts.jpg shroud fitted in my old escort, screws to remove it are under flaps where visors clip in.http://i623.photobucket.com/albums/tt320/escortedal/spainparts018.jpgsimply feed wire up a piller if its fitted as standard mate, hope this help you. Thanks for that doesn't sound too bad at all thanks for the pictures they really help. And when you say ford garage do you mean go to a dealers garage? I'm gonna have a look see if I can find the motor now I know what I'm doing. Also how does this help me with getting remote central locking on mine because it's mentioned somewhere on here that it that you need electric sunroof or the wiring to connect rcl? If so what else do I need for that? Thanks again for the info a great help! Link to comment Share on other sites More sharing options...
nathanbromley Posted January 18, 2014 Author Share Posted January 18, 2014 Just found one on eBay pressed buy it now for £20 but it's got all the wires even what I'd need to connect to in the footwell, don't know if that's cheap or not but hay ho. Just need to order the cowling? It was eBay item number 191030882470 don't know how to upload picture yet I'm a bit slow at everything hahaha. Link to comment Share on other sites More sharing options...
escortedal Posted January 19, 2014 Share Posted January 19, 2014 yes main dealer for cover, good price for motor,iircc remote locking sensor is in the courtesy light, so you need to source that. Link to comment Share on other sites More sharing options...
dalelc16 Posted January 19, 2014 Share Posted January 19, 2014 This really is an easy mod.What you take down is what you put up and connect the + and - to the nearest point which runs of the ignition. Link to comment Share on other sites More sharing options...
nathanbromley Posted January 19, 2014 Author Share Posted January 19, 2014 yes main dealer for cover, good price for motor,iircc remote locking sensor is in the courtesy light, so you need to source that. Right that might already be out simply but I ain't sure what do you mean source? And in the courtesy light of the mondeo unit I've got? Link to comment Share on other sites More sharing options...
mike19892007 Posted January 21, 2014 Share Posted January 21, 2014 Lol £20 good price? Local scrappy charged me £4 for a sunroof motor when I done this mod on my old mk6. Nice mod though especially if you make it one touch so you ain't gotta sit there holding the button to open it Link to comment Share on other sites More sharing options...
Hezz Posted January 21, 2014 Share Posted January 21, 2014 Electric sunroofs are fab Link to comment Share on other sites More sharing options...
nathanbromley Posted January 22, 2014 Author Share Posted January 22, 2014 how do I make it one touch remember im slow youll have to explain like youre talking to a child. also do ford still sell the cowling if so whats the finis code Link to comment Share on other sites More sharing options...
adder Posted February 17, 2014 Share Posted February 17, 2014 mk2 mondeo ghia with electric sunroof uses the same motor and switch as the escort.simply undo the three torx bolts holding the motor in mondeo, remove motor and wire from motor to switch also. shroud on mondeo is no use in escort so don't buy one.remove your handle and shroud from escort,bolt in new motor .wires for electric sunroof may be tucked down the drivers footwell, they were in my p reg ghia escort.go to ford garage and order a new shroud for electric sunroof at a cost of around£ 17.fit switch into shround and screw it in.simple really.motor you need from mondeo with switch and wire to switch.http://i623.photobucket.com/albums/tt320/escortedal/Copy2ofspares002.jpg wire for sunroof motor may be here.http://i623.photobucket.com/albums/tt320/escortedal/spainparts016.jpg what plug for motor supply looks like. http://i623.photobucket.com/albums/tt320/escortedal/spainparts.jpg shroud fitted in my old escort, screws to remove it are under flaps where visors clip in.http://i623.photobucket.com/albums/tt320/escortedal/spainparts018.jpgsimply feed wire up a piller if its fitted as standard mate, hope this help you. Thanks for that doesn't sound too bad at all thanks for the pictures they really help. And when you say ford garage do you mean go to a dealers garage? I'm gonna have a look see if I can find the motor now I know what I'm doing. Also how does this help me with getting remote central locking on mine because it's mentioned somewhere on here that it that you need electric sunroof or the wiring to connect rcl? If so what else do I need for that? Thanks again for the info a great help! Hello folks, I thought I would drag this thread up as after looking at it I thought I would have a go at doing it but, after finding the red plug behind the drivers kick panel. I don't think it's going to be long enough to reach ! My question is, is their more tucked away higher up behind the fuse box maybe ? Or, do I cut and extend the wires until they reach ? Any help would be appreciated Cheers Adder Link to comment Share on other sites More sharing options...
Hezz Posted February 20, 2014 Share Posted February 20, 2014 If you've found the red plug then that just needs uncoiling as it will be wrapped up Link to comment Share on other sites More sharing options...
