Posted June 4, 200519 yr Whats the torque setting for the 10bolts on the cyclinder head? i just brought a torque wrench . And when looking in the hayes manual i couldn't see the settings.
June 4, 200519 yr Whats the torque setting for the 10bolts on the cyclinder head? i just brought a torque wrench . And when looking in the hayes manual i couldn't see the settings.<{POST_SNAPBACK}> It's a four-stage process, and should be done in the right order (as in, order in which you do up each bolt, and each stage in the process). I can't remember the exact torque settings and my book is in the workshop, but it's something along the lines of 40lbft, then 70lbft, then 90 degrees with a bar, and another 90 degrees.. but dont quote me on the torque figures, i'll have to check.. With regards to the order, you do opposite ends, so 1 then 10, 2 then 9, etc. HTH
