ryanrs Posted August 10, 2005 Share Posted August 10, 2005 I fitted my Mondeo sunroof motor to my '97 gti the other day, fitted and works perfect, but i fort to myself, as flash as a power sunroof in an escort may be, i fink it can be one better.... my dad has a P-reg *Caugh* vauxhall *Caugh* vectra 1.8 GLX, and with the electric windows, you dont have to hold the button down untill the window is fully open.. You simply press it once to activate it to open, the press again once its open to the level of desire... and the same on closing... sounds complicated...hum hope you all get me! well, it must run on a series of relays (poss 3 per direction (up+down) open switch Clicks one to activate a 2nd that stays on and powers the motor and keep the window opening, and a 3rd that de-activates the motor when the button is pressed for the 2nd time.. ?? I would like to try modify this to my escort's power sunroof switch, so you click the Slide Open (not tilt) button , once and it will open it all the way (basically so you dont have to sit there pointing at the sealing till its rite open!).. If anyone sees sense in this and wants to try beet me to it, plz feel free, and once done, tell me how you did it, as even tho i want to do it myself, i cant really find time! Isnt there a mondeo that has this electric window function? and runs off one relay? Link to comment Share on other sites More sharing options...
sortedford Posted August 10, 2005 Share Posted August 10, 2005 steve has it, im sure hell reply when he sees this, i believe you use mondeo one touch relays Link to comment Share on other sites More sharing options...
bluliz Posted August 10, 2005 Share Posted August 10, 2005 clicky and it can be done on windows and sunroof's, nice mod if ur handy with a soldering iron! come on Ian, its pinned at the top!!! Link to comment Share on other sites More sharing options...
ryanrs Posted August 11, 2005 Author Share Posted August 11, 2005 Cheers.. quick question tho.... sorry if the answer is already in the topic and i have'nt seen it... The relay used, what relay is it? and where is it located? Link to comment Share on other sites More sharing options...
bluliz Posted August 11, 2005 Share Posted August 11, 2005 Cheers.. quick question tho.... sorry if the answer is already in the topic and i have'nt seen it... The relay used, what relay is it? and where is it located?<{POST_SNAPBACK}> iirc its in the whole unit. sort of built in to the motor housing Link to comment Share on other sites More sharing options...
ryanrs Posted August 11, 2005 Author Share Posted August 11, 2005 Cheers.. quick question tho.... sorry if the answer is already in the topic and i have'nt seen it... The relay used, what relay is it? and where is it located?<{POST_SNAPBACK}> iirc its in the whole unit. sort of built in to the motor housing<{POST_SNAPBACK}> Hum, now to show how fick i really am.... WTF is iirc ?? Link to comment Share on other sites More sharing options...
bluliz Posted August 11, 2005 Share Posted August 11, 2005 (edited) if i remember correctly took me a while to work that one out oh yeah in answer to ur earlier question the relay for the sunroof is in with the motor and casing. i'm not sure where the relays are for the one shot windows. have a check on a mondeo in a scrap yard, most likely the doors as the switches are there. Edited August 11, 2005 by bluliz Link to comment Share on other sites More sharing options...
