Stu Posted October 11, 2007 Author Share Posted October 11, 2007 Purchased some dampers today.. They're DeCarbon ones so should be fairly nice (OEM Gas type).. The fronts aren't 100% DeCarbon but I need to check when they arrive.. Only £52 for all four, brand new, thanks to the wonders of the 'bay. http://i20.ebayimg.com/05/i/000/ba/d6/4d26_1_b.JPGhttp://i24.ebayimg.com/05/i/000/ba/d6/52f3_1_b.JPG I will most likely use a set of Eibach springs with these dampers, but I am potentially going to get the rear beam modified to have adjustable ride height Link to comment Share on other sites More sharing options...
reid Posted October 11, 2007 Share Posted October 11, 2007 Purchased some dampers today.. They're DeCarbon ones so should be fairly nice (OEM Gas type).. The fronts aren't 100% DeCarbon but I need to check when they arrive.. Only £52 for all four, brand new, thanks to the wonders of the 'bay. http://i20.ebayimg.com/05/i/000/ba/d6/4d26_1_b.JPGhttp://i24.ebayimg.com/05/i/000/ba/d6/52f3_1_b.JPG I will most likely use a set of Eibach springs with these dampers, but I am potentially going to get the rear beam modified to have adjustable ride height so are they just standard dampers? whats the difference between decarbon and standard ford ones? Link to comment Share on other sites More sharing options...
Stu Posted October 11, 2007 Author Share Posted October 11, 2007 Probably not much as the standard ones are very good.. Link to comment Share on other sites More sharing options...
Stu Posted October 23, 2007 Author Share Posted October 23, 2007 Well my turbo manifold arrived today and i've had a little play... Thanks to ploppy for the donor vehicle (he doesn't know yet)..... A slight packaging issue may be on the cards http://di.cx/gallery/albums/escort_saloon/stu_a300_071023_005.sized.jpg http://di.cx/gallery/albums/escort_saloon/stu_a300_071023_006.sized.jpg I do intend to have the turbo manifold flange cut at an angle to bring the turbo back in towards the head, but who knows if it'll be enough! I think the turbo is gonna hit teh bonnet too, so some creativity may be required there...... Link to comment Share on other sites More sharing options...
Stu Posted October 23, 2007 Author Share Posted October 23, 2007 Just had a quick measure done by ploppy and the cam cover<>slam panel gap on an Escort is 170mm......... unfortunately the gap on the fiesta above is 200mm which means the escort is even tighter! Definate challenge............ Link to comment Share on other sites More sharing options...
Tez162003 Posted October 24, 2007 Share Posted October 24, 2007 now thats one way to position a turbo! lol, like it! hope you can get around the space issue! Link to comment Share on other sites More sharing options...
Stu Posted October 24, 2007 Author Share Posted October 24, 2007 Where there's a will, there's a way! Link to comment Share on other sites More sharing options...
Tez162003 Posted October 24, 2007 Share Posted October 24, 2007 EXACTLY!!!! go get to it! lol Link to comment Share on other sites More sharing options...
nick_ov_uk Posted October 24, 2007 Share Posted October 24, 2007 stu, how do intend to make the rear beam adjustable? im working on a idea to correct the ride hight to normal when using a mk5 beam on a mk6. Link to comment Share on other sites More sharing options...
Stu Posted October 24, 2007 Author Share Posted October 24, 2007 stu, how do intend to make the rear beam adjustable? im working on a idea to correct the ride hight to normal when using a mk5 beam on a mk6. Not sure yet, i've not even taken my beam out of it's shrink-wrap I did have a quick glance at a mk5b in at the moment and it may be possible just to weld new mounts onto the beam with a slot in for adjustment.. It's not really rocket science though, as long as you do it safely.. Link to comment Share on other sites More sharing options...
nick_ov_uk Posted October 24, 2007 Share Posted October 24, 2007 oh your doing it that way, im doing mine like a sandwhich plate in between the mount and the chassis i might give them both a try and see whats best. Link to comment Share on other sites More sharing options...
RyanML Posted October 24, 2007 Share Posted October 24, 2007 what front brakes are you gonna be using? im not sure if you have already mentioned it lol Link to comment Share on other sites More sharing options...
Trig Posted October 24, 2007 Share Posted October 24, 2007 Where there's a will, there's a way! Angle grinder Link to comment Share on other sites More sharing options...
ScORTED Posted October 24, 2007 Share Posted October 24, 2007 have fun getting that lot in there Link to comment Share on other sites More sharing options...
Stu Posted October 24, 2007 Author Share Posted October 24, 2007 oh your doing it that way, im doing mine like a sandwhich plate in between the mount and the chassis i might give them both a try and see whats best. I'm really not sure yet, it's a while away from being looked at. I might even yet go for some coilovers to my spec. for the road which nullifies any problem with ride height. what front brakes are you gonna be using? im not sure if you have already mentioned it lol No idea yet but probably ST170 brakes (as i'm using 16" wheels). Looking to use a Cosworth brake pump (servo) for the ultimate pedal feel! Where there's a will, there's a way! Angle grinder That most definately will be getting used..... have fun getting that lot in there It's all about the challenge Link to comment Share on other sites More sharing options...
