jamesgti Posted April 15, 2009 Share Posted April 15, 2009 you know the bumper strips on the side of the doors are they hold on by glue? is it flat behind them? Link to comment Share on other sites More sharing options...
fluff2007 Posted April 15, 2009 Share Posted April 15, 2009 When they are taking off its just flat behide them. It leave loads of rubber glue kinda stuff which is very easy to take off hope this helps Link to comment Share on other sites More sharing options...
reid Posted April 15, 2009 Share Posted April 15, 2009 When they are taking off its just flat behide them. It leave loads of rubber glue kinda stuff which is very easy to take off hope this helpssure? didn't think so. it leaves two creases the same size as the bumpstrip behind it. Link to comment Share on other sites More sharing options...
Frazer_d Posted April 15, 2009 Share Posted April 15, 2009 (edited) When they are taking off its just flat behide them. It leave loads of rubber glue kinda stuff which is very easy to take off hope this helps Wrong. When they are taking off its just flat behide them. It leave loads of rubber glue kinda stuff which is very easy to take off hope this helpssure? didn't think so. it leaves two creases the same size as the bumpstrip behind it. Right. It leaves a recess where they should be. Fraz Edited April 15, 2009 by Frazer_d Link to comment Share on other sites More sharing options...
PeeWee Posted April 15, 2009 Share Posted April 15, 2009 And the glue isnt "really easy" to remove either, not the worst job but certainly expect some sore fingers lol. Link to comment Share on other sites More sharing options...
shawdreamer Posted April 15, 2009 Share Posted April 15, 2009 And the glue isnt "really easy" to remove either, not the worst job but certainly expect some sore fingers lol. best time of year to do it tho..... wait for the sun to get at the motor, make sure the strips get plenty of sun heat (rubbers nice and hot after a few hours) then take a paint striper gun and blast the end of a strip (dont touch the paint with the gun just blast at the strip from around 10" away) making sure that most of the heat go's under the edge of the strip. Id suggest you use some gloves to handle the strip now cos they retain heat quite well.... work the edge of the strip slowly until you can get your fingers under it then blast some more heat under to loosen up the leading edge of the M3 foam tape(what the strips are fastened with in the factory), after that its a case of slowly pealing the strip away from the bodywork occassionally blasting some heat in again to keep the momentum goin. if your careful and use enough heat(try to direct most of it at the bodywork rather than the strip) you'll find the strip will come away with the foam attached entirely to that and not to the bodywork saving you cleaning and picking it off afterwards. Link to comment Share on other sites More sharing options...
dutchkev Posted April 15, 2009 Share Posted April 15, 2009 or WD40 works well on the stubborn sticky stuff Link to comment Share on other sites More sharing options...
shawdreamer Posted April 15, 2009 Share Posted April 15, 2009 or WD40 works well on the stubborn sticky stuff true, handy if you fail to pull it off with the strip Link to comment Share on other sites More sharing options...
jamesgti Posted April 16, 2009 Author Share Posted April 16, 2009 cheers for the help guys Link to comment Share on other sites More sharing options...
**caz** Posted April 16, 2009 Share Posted April 16, 2009 sorry to snipe ya thread, but i was thinking of doing this! only thing im worried about is the fact my car is red, and u know what they are like for fading! if i remove the strips am i going to have a really deep red strip surrounded with what will look faded? x Link to comment Share on other sites More sharing options...
mykez69 Posted April 16, 2009 Share Posted April 16, 2009 sorry to snipe ya thread, but i was thinking of doing this! only thing im worried about is the fact my car is red, and u know what they are like for fading! if i remove the strips am i going to have a really deep red strip surrounded with what will look faded? x probably lol but however, you can restore rednes back to a near enough good shade best bet is to remove the one on the wing, as its only small see what is happening behind there if it is darker than the rest of the car behind the bump strip try polishing it all up in that area, see if you can get it to match if you cant, just put the small wing one back on and never think about it again Link to comment Share on other sites More sharing options...
Frazer_d Posted April 16, 2009 Share Posted April 16, 2009 sorry to snipe ya thread, but i was thinking of doing this! only thing im worried about is the fact my car is red, and u know what they are like for fading! if i remove the strips am i going to have a really deep red strip surrounded with what will look faded? x probably lol but however, you can restore rednes back to a near enough good shade best bet is to remove the one on the wing, as its only small see what is happening behind there if it is darker than the rest of the car behind the bump strip try polishing it all up in that area, see if you can get it to match if you cant, just put the small wing one back on and never think about it again Good idea mate. You could just colour code them and they won't stand out. Fraz Link to comment Share on other sites More sharing options...
**caz** Posted April 16, 2009 Share Posted April 16, 2009 probably lol but however, you can restore rednes back to a near enough good shade best bet is to remove the one on the wing, as its only small see what is happening behind there if it is darker than the rest of the car behind the bump strip try polishing it all up in that area, see if you can get it to match if you cant, just put the small wing one back on and never think about it again will prob give that a go when i get a chance! lol Good idea mate. You could just colour code them and they won't stand out. Fraz how easy is that to do? can i colour code the ones i have on the car at the mo? x Link to comment Share on other sites More sharing options...
Craig855S Posted April 16, 2009 Share Posted April 16, 2009 take em off,spray em,and refit em as those 2 recesses look pants IMO Link to comment Share on other sites More sharing options...
perculator Posted April 16, 2009 Share Posted April 16, 2009 anyone got any pix with the strips off, been thinking of doing this myself, need to know weather to remove or colour code Link to comment Share on other sites More sharing options...
