Valve replacement
LiamGTR
Shouldnt be expensive at all, its literally a 1 minute job mate to change a valve I change tyres at work :) Not sure of the exact price, but you'll want to get them to bead seal round the edge and put a new valve in, should be good as new then providing obviously nothings penetrated the tyre. Edited by Escort_Kid
Lmao, good advice mate ;) If they are going to class it as a puncture repair I may aswell ask them to check if it is actually a slow puncture while they are at it ?
What you can do it pump the tyre up to the right pressure, maybe a tad more for luck, and put it in a tub or bath of water....you will be able to see bubbles from where its leaking!!!
