Barry-334 Posted July 22, 2009 Share Posted July 22, 2009 Me again... having a problem with my laptop (Acer Aspire with Vista Home Basic). Without warning, while in the middle of something, it'll just shut down. No error messages, no pass go and collect £200, just off. Also seems to be quite hot underneath. Try and reboot, and shuts down again. eventually got it to restart, but because of the previous failed attempts to restart, it goes into "recovery mode" searching for errors. Not sure if the heat thing is related. wondered whether it has a built-in shut down if it gets too hot, but haven't been using it extensively. (half an hour or so at a time). I have opened the rear cover and checked the fan. It comes on when you boot up and then goes off. it does kick back in when you run any applications, so assume this is normal. any help would be appreciated. Cheers Link to comment Share on other sites More sharing options...
eetaylog Posted July 22, 2009 Share Posted July 22, 2009 overheating would cause your laptop to shutdown as they have an auto shutdown when the system reaches a critical level. where do you use your laptop? as stupid as it sounds, its best not to have them on your lap as the fans will struggle to get rid of the heat. try using it in a way that is less restrictive to the fan exhaust. Link to comment Share on other sites More sharing options...
mykez69 Posted July 22, 2009 Share Posted July 22, 2009 sounds like it is over heating dont use on your lap, as said above, if you do need to use it on your lap, you can get a cooling system that the laptop sits on with extra fans that are powered by USB Link to comment Share on other sites More sharing options...
Barry-334 Posted July 22, 2009 Author Share Posted July 22, 2009 used to use in either on my lap, or on the bed. When I first realised it was getting hot, I started using it sat at a desk, so it can be properly ventilated. but still have the same problem... Link to comment Share on other sites More sharing options...
caled Posted July 22, 2009 Share Posted July 22, 2009 The BIOS should say whether its set to turn itself off it the CPU reaches a certain temperature, if its that then you'll need to make sure all the air vents are clear from dust and that there is always plenty of room around the exhaust vents. Alternatively, it could be windows crashing and automatically rebooting, to check if its this you can simply disable the automatic reboot, which will show you a BSOD. to do this on Vista, go to the control panel, click on system, then under tasks select System protection. The system properties box will pop up, select the Advanced tab and then the settings button under startup and recovery. here, make sure that Automatically restart under the system failure box is NOT selected. Saying all that, my money is on automatically shutting down due to temperature. yeah, you really dont want to use it lying on a bed, itll get really hot really quick Link to comment Share on other sites More sharing options...
Barry-334 Posted July 22, 2009 Author Share Posted July 22, 2009 can't be the auto-reboot, as it doesn't restart, just shuts down. but if it is the high temperature, how come it has only started doing it? had a look at the fan last night, and there was no build up of dust etc on the inside. although there was a lot of copper inside the machine, which was getting warm. didn't realised they used copper components! Link to comment Share on other sites More sharing options...
eetaylog Posted July 22, 2009 Share Posted July 22, 2009 (edited) can't be the auto-reboot, as it doesn't restart, just shuts down. but if it is the high temperature, how come it has only started doing it? had a look at the fan last night, and there was no build up of dust etc on the inside. although there was a lot of copper inside the machine, which was getting warm. didn't realised they used copper components! the copper is probably the part of the processor heatsink. Edited July 22, 2009 by eetaylog Link to comment Share on other sites More sharing options...
duffa Posted July 22, 2009 Share Posted July 22, 2009 download this and see how hot your laptop is running click Link to comment Share on other sites More sharing options...
Stu Posted July 22, 2009 Share Posted July 22, 2009 The copper will be part of a heat-pipe assembly. Link to comment Share on other sites More sharing options...
