Mk6 Si Ross Posted August 2, 2009 Share Posted August 2, 2009 I've got various programs that i don't know what they doAdd/Remove programms part of the Control panel, i also have various versions of updates for things like Java etc, called Java 6 update 3, 4 or 5 etc, can i delete the older ones?? will i start making things not work properly?? any help would be appriciated, ta Link to comment Share on other sites More sharing options...
sidrick Posted August 2, 2009 Share Posted August 2, 2009 Uninstall all Java. Install just the latest one from Java.com Link to comment Share on other sites More sharing options...
wwwd Posted August 3, 2009 Share Posted August 3, 2009 Get a second hard drive. Link to comment Share on other sites More sharing options...
Stu Posted August 4, 2009 Share Posted August 4, 2009 The JRE is the last of your issues if your HD is full. Link to comment Share on other sites More sharing options...
Mk6 Si Ross Posted August 4, 2009 Author Share Posted August 4, 2009 The JRE is the last of your issues if your HD is full. does sem to be the tip of the iceberg. Whats all these Microsoft.Net Framework programs??? Where else can i look for stuff to delete?? Link to comment Share on other sites More sharing options...
mykez69 Posted August 4, 2009 Share Posted August 4, 2009 music and videos will be taking up most of your hard drive space Link to comment Share on other sites More sharing options...
scottg17 Posted August 4, 2009 Share Posted August 4, 2009 how bigs your drive? Link to comment Share on other sites More sharing options...
RickH Posted August 4, 2009 Share Posted August 4, 2009 The JRE is the last of your issues if your HD is full. does sem to be the tip of the iceberg. Whats all these Microsoft.Net Framework programs??? Where else can i look for stuff to delete?? The .NET framework is basically what it says. It is a framework that a lot of other programs and applications use that are created for the Windows platform. Get yourself a second hard drive - or an external drive you can plug in via usb. Transfer things like pictures & videos to it that you dont really need and remove them from your day to day drive. Link to comment Share on other sites More sharing options...
slayer666 Posted August 4, 2009 Share Posted August 4, 2009 delete all your unwanted items by doing disc clean up eg: cookies, temp folders and history. Then defrag it, pics and stuff like that put them onto photo shop and then put them onto disc as back up and remove all programs u dont use. Then itll be best if u get an external HDD for your music which and other folders eg: documents and downloads. which will clear alot of space up on the original hdd or if its a tower your using just buy an extra standard hdd which is slightly cheaper Link to comment Share on other sites More sharing options...
geordie_aaron Posted August 5, 2009 Share Posted August 5, 2009 Then defrag it, pics and stuff like that put them onto photo shop and then put them onto discwhat's photoshop got to do with backing up photos.... it's a EDITING program?! Link to comment Share on other sites More sharing options...
Lee_2f2f Posted August 5, 2009 Share Posted August 5, 2009 (edited) Like everyone has said Ross, I would say the same as thats what I do. My laptop's HDD is 80GB, I use that for Windows, and installations; I then have a 500GB Network External HDD, which has all my Music, Photo's, Video's & Program's on; Having the drive Networked is a massive help as my Laptop, PC & PS3 can all access at the same time without having to lug the HDD from room to room. Take a look on www.pcworld.co.uk as some of the network drives seem Kinda' cheap at the moment. Also, by not having all that Gunk on the same HDD as your operating system, IIRC it should run a bit smoother, could be wrong though. Edited August 5, 2009 by Escort_2f2f Link to comment Share on other sites More sharing options...
