gtichris Posted September 21, 2010 Share Posted September 21, 2010 had a little scout but cnt find any topics on this. been told best brakes for the mk6 escort is focus st170 front plus rear. is this true? what is everything i will need an will i need 17" wheels for deffo etc an what braided hoses do i need? il be buying uprated discs an pads for front an rear just could do with a part list from wich car an what rear axel to use as mine is drums on the back thanks Link to comment Share on other sites More sharing options...
Stu Posted September 21, 2010 Share Posted September 21, 2010 Depends what you consider as 'best'. Easiest? Possibly. But then again, bolting on a purpose-built set of AP's is also 'easy'. Cheapest, best value for money? Sure, the ST170 front setup is good. I wouldn't do the rears though, unless you intend to get new rear wheels with a correcting offset on it (alternatively suffer the handling hit). ST170 front setup with Ferodo DS2500 pads is pretty awesome. Even better with a larger master cylinder. Link to comment Share on other sites More sharing options...
projectrs2k Posted September 21, 2010 Share Posted September 21, 2010 had a little scout but cnt find any topics on this. been told best brakes for the mk6 escort is focus st170 front plus rear. is this true? what is everything i will need an will i need 17" wheels for deffo etc an what braided hoses do i need? il be buying uprated discs an pads for front an rear just could do with a part list from wich car an what rear axel to use as mine is drums on the back thanks right mate i have the setup on my car both front and back firstly for the front you will need focus st170 discs mk3 mondeo calipers adn pad carriers mk1 mondeo brake hoses and you will need to drill the holes in the hub out to 11.5 mm as the mondeo bolts are bigger for the rear you will need full focus rear hub setup (this bolts off from the axle )focus brake hoses as the escort ones will screw into themor puma braided hosesfocus handbrake cable you can use escort one but you will have to have some adaptor plates made up if your car has abs then you will have to have the hubs machined and drilled to fit the escort abs ring and sensor as focus is different and last but not least the minimum wheel size you will need is 16" Link to comment Share on other sites More sharing options...
DaweV6 Posted September 21, 2010 Share Posted September 21, 2010 and last but not least the minimum wheel size you will need is 16" Generally yes, but as I found out they'll JUST fit under some 15" - like these for example - http://www.bildon.com/catalog/Admin/photos/large/RALLY1.jpg Or these - http://img814.imageshack.us/img814/6646/hpim0915.jpg So you don't have to increase wheel size and loose power, just to find some very good ones. Link to comment Share on other sites More sharing options...
JC Posted September 22, 2010 Share Posted September 22, 2010 ST170 front setup with Ferodo DS2500 pads is pretty awesome. Even better with a larger master cylinder. very true there Stu my bro runs that set up! What master cylinder can you "up grade" to on a escort? Link to comment Share on other sites More sharing options...
Stu Posted September 22, 2010 Share Posted September 22, 2010 ST170 front setup with Ferodo DS2500 pads is pretty awesome. Even better with a larger master cylinder. very true there Stu my bro runs that set up! What master cylinder can you "up grade" to on a escort? Not sure. Various will fit, whether or not they're an upgrade or not is another matter. I've not done the test. Once upon a time, I looked at fitting an ST220 one but deemed it too much hassle so binned the idea. Link to comment Share on other sites More sharing options...
JC Posted September 22, 2010 Share Posted September 22, 2010 ok thanks! Link to comment Share on other sites More sharing options...
gtichris Posted September 22, 2010 Author Share Posted September 22, 2010 thank you very much. will the focus hubs bolt to my axle ok with it been drums? i have no abs to worry about an im going 17" anyway so il gt it al sourced soon cheers Link to comment Share on other sites More sharing options...
rodssescort Posted September 22, 2010 Share Posted September 22, 2010 the focus hubs will bolt straight on mate, i had st170 setup all round and it was awsome Link to comment Share on other sites More sharing options...
