Andyb0127 Posted December 6, 2010 Share Posted December 6, 2010 As I'm off work soon I want to service my escort, my query is which oil would be best to use at the moment it has castrol magnatec 10/40 in it, would it be worth using this again or is there a better oil for the same price. Link to comment Share on other sites More sharing options...
Stu Posted December 6, 2010 Share Posted December 6, 2010 Ford recommend 5w30. Link to comment Share on other sites More sharing options...
etrebus Posted December 6, 2010 Share Posted December 6, 2010 (edited) As I'm off work soon I want to service my escort, my query is which oil would be best to use at the moment it has castrol magnatec 10/40 in it, would it be worth using this again or is there a better oil for the same price.if you have a zetec engine it should be 5w30 i would get it from ford Edited December 6, 2010 by etrebus Link to comment Share on other sites More sharing options...
hicksy Posted December 6, 2010 Share Posted December 6, 2010 5w30 as stu said is what ford recommend Link to comment Share on other sites More sharing options...
georgeh811 Posted December 6, 2010 Share Posted December 6, 2010 i put 10/40 in the focus the past 2 services as i found it was eating the recommended oil na few people said i was be ff changing grade. that said, the engine must be worn to eat the oil like it was but since changing grade it has been great Link to comment Share on other sites More sharing options...
Andyb0127 Posted December 6, 2010 Author Share Posted December 6, 2010 Yes it's a 1.6 zetec, thanks for the advice and help guys appreciate that, I'll order it from ford :-))))))) Link to comment Share on other sites More sharing options...
PeeWee Posted December 7, 2010 Share Posted December 7, 2010 i put 10/40 in the focus the past 2 services as i found it was eating the recommended oil na few people said i was be ff changing grade. that said, the engine must be worn to eat the oil like it was but since changing grade it has been great Im not 100% sure but didnt using grades such as 10/40 cause eventual sticking valves on Zetecs? Link to comment Share on other sites More sharing options...
waynegc123 Posted December 7, 2010 Share Posted December 7, 2010 I use 10w60 Link to comment Share on other sites More sharing options...
georgeh811 Posted December 7, 2010 Share Posted December 7, 2010 Im not 100% sure but didnt using grades such as 10/40 cause eventual sticking valves on Zetecs? I was under the impression that it was the older zetecs that suffered with sticky valves Link to comment Share on other sites More sharing options...
Stu Posted December 7, 2010 Share Posted December 7, 2010 It was the very first engines that did, either way i'm not sure why anyone would want to go from a 5w to a 10w in this country. All it'll do is make lubrication worse when cold. Link to comment Share on other sites More sharing options...
SteveB Posted December 7, 2010 Share Posted December 7, 2010 I think the early handbooks say 10/40 - late handbooks say 5/30. There's no major difference in the engine though - as said, Ford realised that 10/40 caused valve stick and changed the specified oil. Link to comment Share on other sites More sharing options...
