Billkent22 Posted April 11, 2012 Share Posted April 11, 2012 Right got this weird water leak, ive never seen it on a scort before but maybe ive just been lucky.... Anyone else had this issue and how did you fix it, im guessing its where the seals gone weak or something..... http://i59.photobucket.com/albums/g308/billkent22/8166824f.jpg http://i59.photobucket.com/albums/g308/billkent22/ea651b36.jpg Link to comment Share on other sites More sharing options...
Mike-evans Posted April 11, 2012 Share Posted April 11, 2012 Yep seen this. Mine had a tear in the seal about 3-4" back from where you got the puddle.. Check for a tear there.. Link to comment Share on other sites More sharing options...
tomsy Posted April 11, 2012 Share Posted April 11, 2012 Mine leaks in that place to only when i wash it using a hose though,and i also had a 18 month old sportka that had the same problem might be a design fault with the seals. Link to comment Share on other sites More sharing options...
Billkent22 Posted April 19, 2012 Author Share Posted April 19, 2012 Had a look for a split in the seals but couldn't see anything, starting to be annoying now.Every time it rains I expect a puddle! Link to comment Share on other sites More sharing options...
shawdreamer Posted April 19, 2012 Share Posted April 19, 2012 worth checking your window seal too, if its not seated properly or deteriorated in anyway excessive water can run down the window and drain out the door interior (as it should normally) but excessive water can force its way backwards against the seal and into the cab. Link to comment Share on other sites More sharing options...
Billkent22 Posted April 25, 2012 Author Share Posted April 25, 2012 Im not having much luck finding this so far! And with all this awsome rain its not good! Ive checked the whole seal, no splitsIve checked the screen seals, look good to meAlso theres no water between the top seal ans the one that seals the door so what i suspect is the water thats coming in is the water running down the door and collecting on the sill, just cant understand how or how to bloody fix it! Link to comment Share on other sites More sharing options...
etrebus Posted April 26, 2012 Share Posted April 26, 2012 Im not having much luck finding this so far! And with all this awsome rain its not good! Ive checked the whole seal, no splitsIve checked the screen seals, look good to meAlso theres no water between the top seal ans the one that seals the door so what i suspect is the water thats coming in is the water running down the door and collecting on the sill, just cant understand how or how to bloody fix it!check top part of door is sealing against roof door tops are quite easy to bend out of shape (especially if someone has had to break in levering door top out )just a thought Link to comment Share on other sites More sharing options...
Billkent22 Posted June 16, 2012 Author Share Posted June 16, 2012 --------FIX--------- Just want to let everyone know how this was resolved as im sure it may help some of you in the future. It was as some of you did mention the door membraine. I took the door card off and found that the door had been sprayed at some point ( with the membraine removed) this ment that they over sprayed onto the sealent causing it not to seal the membraine to the door. So i cleaned it sll up and sealed it back up with some wurth stuff! All good Bill Link to comment Share on other sites More sharing options...
tomsy Posted June 16, 2012 Share Posted June 16, 2012 Thanks for posting this always nice to know that a problem has been solved and how. Link to comment Share on other sites More sharing options...
Naylor2006 Posted June 16, 2012 Share Posted June 16, 2012 Thanks for posting this always nice to know that a problem has been solved and how. I agree. The amount of topics that die as soon as the person fixes the problem but dont post as to what that fix was, you find your self doing a search and finding someone with your symptoms and you keep scrolling going, 'yes yes this looks like it' then theres no final resolve Link to comment Share on other sites More sharing options...
Billkent22 Posted June 17, 2012 Author Share Posted June 17, 2012 I agree, i bloody hate that! Ive spent countless hours wasting my time reading threads, hence why i thout i would post up the fix! Link to comment Share on other sites More sharing options...
